Jay, ever get around to the full list of stuff you offer? Any way you can start turning out strut rod bushings? I know it was brought up to Doug 4+ years, but he turned it down because you could still get factory kits at the time. Think of the market for them...
Hey guys, sorry for the long delay. I do most of my internetting on a smartphone, and didn't want to have to type this all out on such a small screen...
Anyway, here's a list of everything I can make:
-Delrin rear LCA bushings - $325 shipped
-Delrin rear knuckle bushings - $325 shipped
-UMHW subframe bushings - $325 shipped
If you buy any 2 of the above bushing sets at the same time, the total is discounted to $600 shipped.
If you buy all 3 of the above bushings at the same time, the total is discounted to $900 shipped.
-UHMW spring perches for the Mark VIII rear LCA's - $150 shipped
- $180 shipped with the Prothane 61709 poly spring isolators included
-Stainless steel steering u-joint and stub shaft - $150 shipped
-Stainless steel strut rod bushing sleeves - $135 shipped
-Stainless steel rear brake caliper relocation brackets for Cobra rotors - $80 shipped
-Energy Suspension rear sway bar bracket kit - $75 shipped
The following items are for Mark VIII's only:
-Stainless steel solid coolant crossover plug - $40 shipped
-Stainless steel coolant crossover plug with a 1/8"npt drilled/tapped hole through the center for water temp sensor, etc... - $45 shipped
-Stainless steel shock mount kit (includes all SS hardware, Energy Suspension poly bushings, and SS washers) - $66 shipped
-Delrin HID adapters - $50 shipped
-Plug/play aftermarket HID kit (for 97/98, and 96 LSC only) - $165 shipped
If you have any questions, please feel free to ask. I can also do other machining/lathe work if you happen to have a project that you need done.
