control arm install - TCCoA Forums
post #1 of 27 (permalink) Old 07-07-2015, 06:56 AM Thread Starter
irvin's Avatar
control arm install
seeings i havent done this on these cars, any tips on installing? not
many miles ,but a boot is split. should you have to realign the front
end? any help appreciated. looks simple but you guys are the experts.
any other parts that have to come off to get them out?
96 XR7-36000 miles- pretty much mint
4.6--ZU blue, all leather,autolamp.auto temp
r. power seat added .sold in july-14
bought back-dec,14 left w/25000.came
back w/36000.
irvin is offline
post #2 of 27 (permalink) Old 07-07-2015, 07:21 AM
For the upper arm - 1) You'll just about need a 18mm ratcheting box wrench to get the nuts off inside. 2) When reassembling, Ford recommends putting the control-arm-to-shock-tower bolts in, leveling the arm, torquing the bolts down, THEN connecting the ball joint.
OTGH, there are folks ( Robert for one ) who have replacement boots if the ball joint is still in good shape. You'll probably need to use a needle injector to refill it with grease when done, but still.
Fuelly
RalphP is offline
post #3 of 27 (permalink) Old 07-07-2015, 08:20 AM Thread Starter
irvin's Avatar
only one oem control arm left at vintage so i bought the delco ones. they look
identical,even the boot retainers are green. no zerk. was gonna get lowers, but no delcos anywhere. i do have the service manual , but you guys have the real world knowhow. thank you!
back w/36000.
irvin is offline
post #4 of 27 (permalink) Old 07-08-2015, 03:14 PM
Tbird Bob's Avatar
Those nuts are much smaller than 18mm. I'm in the planning stage of doing this job and today I tried several different sizes of wrenches. The nut measures 15mm, but my 15mm socket is too big, the 14 is too small. I'm thinking their must be a special tool needed, but the only thing mentioned in my Ford factory manual is to use a 6 point socket.
Has anyone here been through this and know the correct size? Also, the instructions say to break off the flag on the bolt before removing the nut. I don't see the reason for this. The new parts don't have a flag. How does one snap of the flag?
Tbird Bob is online now
post #5 of 27 (permalink) Old 07-08-2015, 03:38 PM
gordonm1's Avatar
I just did my 1992 this spring and they probably weren't needed. The key one for me was the tie rod end ball joint. It had a tiny bit of play. My brake rotors were making everything wobble when applied.
You can try oiling your upper control arm bushings to see if they will get quieter and keep rolling if your front end is tight and there are no noises. People let these cars sit for a few years with lots of road salt on them and the ball joints seize and fail.
My new control arms were Moog uppers and the dust boot split before I got it installed. That's not going to hold grease and its going to rust a lot in a road salt environment before any real wear happens at the joint. I get catalogues from Duluth Trading with a supertape I may try to use to hold some grease against the ball joint in the upper control arms by taping around my failed dust boots. More money for RobertP's new dust boots but better.
gordonm1 is offline
post #6 of 27 (permalink) Old 07-08-2015, 04:50 PM
18mm on mine when I changed them. Leave the flags there, you'll need them when it's time to tighten things back up.
post #7 of 27 (permalink) Old 07-08-2015, 06:38 PM
I don't mean to hijack your thread - especially as a newbie, but I am working on this aspect of my Mark VIII right now. My UCA to body mount nut also measures 18mm. I realized too late that a ratcheting box wrench would have been perfect - after it took two hours to take off and re-attach. I changed my tie rod ends and control arms, had it aligned, and now it doesn't drive right. It is vague and twitchy, not precise and well-weighted like it was. I changed the parts trying to fix a shimmy when braking at high speed. Its fixed, but doesn't feel right anymore. I am going thru everything once more to see if something is loose, or assembled wrong. Couldn't torque the nut by the brake booster - no room.
olddavidp is offline
post #8 of 27 (permalink) Old 07-08-2015, 07:06 PM
Most likely, the alignment shop tightened the bolts with the wheels off the ground.
That really jacks up the suspension.
post #9 of 27 (permalink) Old 07-08-2015, 08:46 PM
I assume your talking about the drivers front upper rear control arm nut? I ran into the same thing and had to pull off the master to tighten it. Then bleed the brakes all the way around. This was on a couger not a MK8. Absolutely no mention of needing to pop off the Master cylinder in the shop manual. But in my case there was no way of getting a wrench or socket of any type in there without removing the Master. All of the lines looked to be factory (to me).
97CatMan is offline
post #10 of 27 (permalink) Old 07-08-2015, 09:29 PM
Tbird Bob's Avatar
Okay, now I'm feeling a bit silly, but I blame it partly on manuals telling me to remove bolts. I mistakenly thought those bolts with 15mm head were what the manual was referring to.
If 97CatMan had not chimed in about his under the hood work, I'd still be scratching my head. I see the four 18mm nuts. Now I see the reason for the flags is to hold the bolt heads in place while loosening the nuts. Correct? I believe I can't go forward without the 18mm ratcheting wrench and possibly an 18mm socket.
Thanks for helping, folks.
post #11 of 27 (permalink) Old 07-08-2015, 10:33 PM
TBird Bob - ayep, that's what the flag is for. And yes, 18mm on the nut.
Fuelly
RalphP is offline
post #12 of 27 (permalink) Old 07-08-2015, 11:10 PM
I noticed in an old Lincolns of Distinction post that one member actually took a hole saw and created a 3 inch hole to access the nut by the master cylinder. I actually contemplated doing it until I decided that I would have to weld it back together to maintain structural integrity, because there is one hole already in that area. Still considering it, as I have decided to start from scratch, connect the upper bolts to the body first - with the UCA out at 90 degrees, then connect the ball joint to the spindle. If that doesn't cure my vagueness problem, then back to the front end shop. Why is it so difficult to get good geometry done on our cars?
post #13 of 27 (permalink) Old 07-09-2015, 05:48 AM
Because it's an unusual design.
I've actually been told "We can't adjust the caster on these cars." I point to the strut rods, and get BS back.
Which is why it goes to ONE shop in town ... and not any of the others in that local chain!
Fuelly
RalphP is offline
post #14 of 27 (permalink) Old 07-09-2015, 06:23 AM Thread Starter
irvin's Avatar
in just replacing the uca"s, does it really need an alignment, or just check toe in?
actually ill probly just do the left.
back w/36000.
irvin is offline
post #15 of 27 (permalink) Old 07-09-2015, 06:35 AM
steamer471's Avatar
You got that right. The local chains never could get my car straight. Got a local guy and my car drives straight as an arrow.
I just did the front end on my mark and have done 5 birds, never had to remove the master. Just takes a lot of patience.
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #16 of 27 (permalink) Old 07-09-2015, 07:55 AM
Disclaimer. I don't own a 18mm rocketing box wrench and needed to get a deep well socket on there to clear the the stud and the bolt. It's entirely possible that the offending brake line had been changed or replaced at some time. But looked normal. I'm not sorry I did that way as I was able to use a torque wrench upon reassembly and the fluid desperately needed flushed.
97CatMan is offline
post #17 of 27 (permalink) Old 07-09-2015, 08:04 AM
I do, so you know who to call when you do UCAs now.
I only reconsider alignment when doing lower suspension stuff, since that's where the bolts are that adjust all the alignment specs are located. Tie rods, LCAs, strut rod... About the only time I might entertain the thought of an alignment when replacing the UCA is if the car was previously aligned with a severely worn out upper ball joint.
post #18 of 27 (permalink) Old 07-09-2015, 10:02 AM
Woodman's Avatar
While even with the 18mm ratcheting box end it's slow work, it's really not so bad, and they don't need replaced very often, especially if you get good parts with grease zerks.
I wouldn't cut a hole in the car to access the bolt easier for that one job personally.
Woodman is offline
post #19 of 27 (permalink) Old 07-09-2015, 03:20 PM
I would check the "thanks" button to all of you, but I am not on that other site. Thank you all for the input. Now to put it to the test by implementation.
post #20 of 27 (permalink) Old 07-09-2015, 04:29 PM
Borrowed the picture from Rick (NetKeym) when he did his drivers side upper arm, figured it might help some people here!
post #21 of 27 (permalink) Old 07-09-2015, 05:02 PM
Tbird Bob's Avatar
Two more thumbs up to everyone for the input. Every bit of input can be important. I say, can be. Sometimes free advice can turn out to be quite expensive, as I've experienced first hand.
This thread is the opposite, as I find every thing here more helpful than the Haynes manual and the Ford factory manual. In them there is no mention of and 18mm wrench, (an easy, helpful fact to include). In addition, it doesn't make sense to break off the flags on the bolts. It seems to me it would make the removal more difficult because as was pointed out the flags keep the bolt heads from turning when removing the nuts from under the hood.
I've decided to forgo buying the 18mm hardware because I am quite certain I will never used it again, and I found out from a buddy who is a professional mechanic, he has all of the 18mm stuff, and the money I would have spent on hardware is going to be spent on some good micro brewed ale. All I have to do is drive over to his house where he will help with the job. This is how I avoid borrowing somebody's tools. I'll let you all know how it goes. Parts from Rock Auto are due in on July 13th.
post #22 of 27 (permalink) Old 07-09-2015, 08:22 PM
steamer471's Avatar
At least you got to torque yours down, I had to guess at mine. I have one no brand wrench that will just fit in there and turn that bolt 2mm at a time. Takes about thirty minutes. It's the only one that will fit.
1997 Mark 8 LSC
Former owner:
post #23 of 27 (permalink) Old 07-09-2015, 09:11 PM
You know me. I'll buy a full set of the damn things I was sure wishing I had one when I was doing it but I don't mind using a click wrench to be sure about the torque either. And I got to spend some quality time with the GF bleeding the brakes
The old parts car got LCA's, strut rod to control arm bushings and bar links during the polar bear parts party two winters ago. The steering wheel ended up straight when I was done and the car drove fine. I was going to get the alignment checked and never got around to it. Tire wear was much better after I replaced the parts without a alignment then before. Some times you get lucky. A lot of these alignment places only set the toe these days then charge you 69.00
The front strut rod to frame bushings, new springs that alter the ride height and tie rod ends are the biggies for me.
97CatMan is offline
post #24 of 27 (permalink) Old 07-09-2015, 11:12 PM
That pic is of a 93+ MN12 or a FN10. 89-92 MN12s, no such hole.
Just in case someone with, say, a 1991 is pulling their hair out looking for it
Also, you should have the suspension loaded, or have the spindle disconnected from the ball joint, when tightening that nut. AND the arm should be level - or at least, at the typical ride angle.
Fuelly
RalphP is offline
post #25 of 27 (permalink) Old 07-10-2015, 07:14 AM
A Mark VIII is an FN10, yes? That is what is see when working on mine except in T.red. I guess the hole is there for a reason. Outstanding thread. Now no excuse for not doing it yourself and doing it right. Just to update, Sears sold me a solo 18mm for $12.
post #26 of 27 (permalink) Old 07-10-2015, 07:31 AM Thread Starter
irvin's Avatar
thanks for all the plus info here. i looked all over my snap on catalog
and never found a micro brewed ale listed. its must be a real new tool or
a discontinued one.
back w/36000.
irvin is offline
post #27 of 27 (permalink) Old 07-10-2015, 07:57 AM
a discontinued one.
I though Ale was a currency? At least in these parts it seems that way.
97CatMan is offline
