Can someone help me with this steering rack issue? - TCCoA Forums
post #1 of 10 (permalink) Old 08-25-2015, 02:23 PM Thread Starter
So I was replacing the high pressure hose and when I finished I went to start my car to run some power steering fluid through the system and I developed a huge leak, I did some investigation and I found that the elbow fitting on the rack isn't fit into the bolt properly.
Picture:
http://imgur.com/vHdOQWW
Is there anyway to fix that without having to remove the steering rack from the car? Or will I have to?
MORE PICTURES:
http://i.imgur.com/LT4lutc.png (From the top)
http://i.imgur.com/NLl8dSq.png (From the bottom, you can see the leak)
Ethan_Agan is offline
post #2 of 10 (permalink) Old 08-25-2015, 05:25 PM
Well, it's a lot easier if you are nimble fingered and use stubby wrenches.
I can't even put the hose on that fitting with the rack out and get it in ...
At your age, I can't quite recommend new profanities to use *grins* (That'd get me in trouble!), but that fitting is NOT designed for mortal humans to manipulate.
If it's leaking, especially at THAT angle, you might need to replace the elbow. I did on my Cougar, because that aluminum gets friable with age and cracks and breaks easily. Boo, hiss!
Suggestion? If you DO pull the rack, grab a set of motor mounts for your 5.0HO and swap them in. That's a LOT easier with the rack out for a fat fingered Big Boy like me
Fuelly
RalphP is offline
post #3 of 10 (permalink) Old 08-25-2015, 06:26 PM Thread Starter
How difficult is removing the rack?
post #4 of 10 (permalink) Old 08-25-2015, 06:51 PM
1996Project-bird's Avatar
It's a 20 min job with the engine out. That's how I just did mine.
1996Project-bird is offline
post #5 of 10 (permalink) Old 08-26-2015, 01:15 AM
V8ThunderCat's Avatar
Did you look at it while the car was running to make sure it was coming from the rack side or hose side?
V8ThunderCat is offline
post #6 of 10 (permalink) Old 08-26-2015, 09:43 AM
Except for the hoses, it's not a big deal. I've done easier - I've seen HARDER *grins*
The biggest pain is the hoses, since for some weird reason Ford's engineers couldn't be arsed to design a front cross member that didn't go right through where the R&P unit had to go ...
I'd HIGHLY recommend getting a new elbow. RockAuto lists three suppliers http://www.rockauto.com/catalog/rafr...&parttype=7320 but I'd bet they're all the same (Don't know, for something that critical I'd spend the bucks for a ACDelco myself.)
If yours has the EVO valve, I'd also check the forum postings and pick up all new seals from Ford.
Fuelly
RalphP is offline
post #7 of 10 (permalink) Old 08-27-2015, 03:58 PM Thread Starter
I have been trying to fiddle with it for a while, but I finally got tired of seeing my poor baby on jack-stands so I put the tires back on lol maybe ill give it another go this weekend. I swear I have the worst luck when it comes to my car.
Definitely coming from the rack side.
To be honest I thought about trying to use PVC cement hahahahaha I have a bad habit of trying to jury rig stuff...
post #8 of 10 (permalink) Old 08-27-2015, 07:45 PM
Don't! Just .... Don't.
NOTHING that is safety critical should EVER be jury rigged. NEVER.
Fuelly
RalphP is offline
post #9 of 10 (permalink) Old 08-27-2015, 07:53 PM Thread Starter
Yeah I totally understand
post #10 of 10 (permalink) Old 08-27-2015, 10:41 PM
dDUBb's Avatar
Pipe dope would work better, I prefer the yellow number 5 soft set over the teflon infused stuff. No seriously, replace the elbow and teflon O ring with new parts .. yours is bent, if it wasnt leaking before, you caused it when you replaced the high pressure hose.
dDUBb is offline
