anything new with shocks? - TCCoA Forums
post #1 of 23 (permalink) Old 09-30-2015, 11:01 AM Thread Starter
Been out of it for a while. I'll be working on mt thunderbird soon as was wondering if there was any new developments in the shocks department. I've been searching and still can't find anything.
A.Baker is offline
post #2 of 23 (permalink) Old 09-30-2015, 11:41 AM
Not that I know of, aside from the Tokico HP "Blues" being available again.
post #3 of 23 (permalink) Old 09-30-2015, 01:52 PM
I'm happy with my monroe sensa-trak, that being said i haven't driven one with the blues, and my factory ones were so bad you could compress the rears by hand and have them stay compressed for way too long.
steveg1988 is offline
post #4 of 23 (permalink) Old 09-30-2015, 02:29 PM
T6Rocket's Avatar
How do you like the Sensa-Trac's "floaty" ride? Mine feels like a boat if I hit a dip in the road at speed, and it has gotten worse now that they have miles on them. Other than that they're great!
The Motorcrafts are no prize either. I put a set on Brenda's car, and after a few years it hit the bumps HARD.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #5 of 23 (permalink) Old 09-30-2015, 02:36 PM Thread Starter
This is news to me. I have little to no experience with anything other than sport shocks. Are these shocks worth getting? And where to get them. I've searched for things like this and came up empty.
A.Baker is offline
post #6 of 23 (permalink) Old 09-30-2015, 02:42 PM
Yes, the Tokico's are pretty much the only good shock for our cars anymore. Monroe's will work fine to keep the car on the road, but the Tokico's are the ones to get if you care about how your car handles.
post #7 of 23 (permalink) Old 09-30-2015, 05:07 PM Thread Starter
Thanks. I do transmission work first. The car has been on the back burner for a bit but suspension is definitely next.
A.Baker is offline
post #8 of 23 (permalink) Old 09-30-2015, 06:47 PM
CDsDontBurn's Avatar
This is good to know!
CDsDontBurn is offline
post #9 of 23 (permalink) Old 10-02-2015, 06:39 PM
The Tokico Illumina II's are out there, too. My advice is to Google the part number and email every supplier that says they have them in stock to verify stock levels before purchase. You will find that while many don't actually have them, some sites do. These can be run without ARC, you'll just switch between soft and firm manually (if you even desire to do so). http://www.sccoa.com/forums/showthre...88#post1060988
post #10 of 23 (permalink) Old 10-02-2015, 07:31 PM
Tokico's are on amazon; they seem pricey to me, but I don't need shocks right now, lol.
Tokico HE3690 HP Rear $105.01
Tokico HU3689 HP Front $95.40
Rears are usually cheaper...
post #11 of 23 (permalink) Old 10-02-2015, 08:21 PM
Looks like the Illumina II's are available on Amazon too, currently. EU3689 and EE3690.
post #12 of 23 (permalink) Old 10-03-2015, 07:08 AM
MaddMartigan's Avatar
Follow me for a second; in fantasy land, would you pick these over the Bilstein B6 shocks?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #13 of 23 (permalink) Old 10-03-2015, 12:22 PM
tbirdtess's Avatar
Well I live near Fantasy Island.
I have Bilstein S7G- 5555 up front.
Hugh difference over the Koni Adjustable's
And they were a big upgrade from KYB's
However maybe too much for a streetcar.
Sorry no progress on upper shock mount as yet.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #14 of 23 (permalink) Old 10-03-2015, 02:32 PM
I've decided to try another route so I was curious about how the Bilstein B6 compares to the Koni's and the Tokico Illumina II's.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #15 of 23 (permalink) Old 10-03-2015, 03:31 PM
What's the specs on these Bilstiens? For that matter what's the spec on Tokicos? Why is it this kind of information is so hard to come by unless they're racing inserts, and how the hell is one to pick racing inserts if there's no benchmark to go by??? I want something much stiffer than the Tokicos, interested to hear the results.
post #16 of 23 (permalink) Old 10-03-2015, 03:43 PM
I have not had an easy time finding that kind of data.
Here are the inserts I'm going to try for the front: http://cart.bilsteinus.com/productsearch/34-050224
Here are the numbers for the Cobra rears: http://cart.bilsteinus.com/productsearch/24-185974
The first ones are B6 which are listed as HD. The second ones are B8's which are listed for sports cars.
That's all I have at the moment.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #17 of 23 (permalink) Old 10-03-2015, 03:50 PM
I've been considering burning out a factory mount, and replacing the old center with a spherical bearing of some sort; similar to some of the mustang race setups.
What do y'all think?
Something like this, only different:
post #18 of 23 (permalink) Old 10-04-2015, 10:33 AM
tbirdtess's Avatar
Similar to my idea.
prob alot cheeper
351W 2bbl.
C-4 Auto
3.90 open rear
post #19 of 23 (permalink) Old 10-04-2015, 04:10 PM
Similar to my idea.
prob alot cheeper
I have a new set of top mounts. I'm not sure I see how to integrate something like this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #20 of 23 (permalink) Old 10-04-2015, 06:12 PM
I haven't tried out the Bilsteins, so I couldn't say. If they were available, I'd buy a set, try them out, and sell whichever set I liked least. I can say that the Tokico Illumina II's are a significant leap from the KYB GR2's, but IMO, the firm setting could be firmer and the soft setting softer.
post #21 of 23 (permalink) Old 10-04-2015, 07:49 PM
For my purposes, the firm setting is what really matters. I'm interested in getting my sled working for autocross and some road course duty.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #22 of 23 (permalink) Old 10-04-2015, 10:01 PM
Mgino96tbird46's Avatar
Is there much of a difference between the Illumina II's and the blues, handling wise?
Mgino96tbird46 is offline
post #23 of 23 (permalink) Old 10-04-2015, 10:33 PM
As far as I recall the Illumina IIs on firm = Blues
