Vogtland Spring alignment numbers - TCCoA Forums
post #1 of 4 (permalink) Old 10-17-2015, 12:01 PM Thread Starter
17Mark71's Avatar
What numbers are needed to tell alignment people for Vogtland Spring install?
'97 Sport Option'd T-Bird
DSS Shortblock, PI Heads, 262AH Cams, Kooks, SVO SC with stock pulley,
42 lb injectors, 70mm TB, '02 GT MAF, Vogtland Springs, Mk VIII DS,
Marauder TC, 17" SVT T-Bird Rims, Michelin PS2 235/50/17, True Duals,
4.10 gears, J-modded tranny
300RWHP 335RWTQ
Member of www.midwestthundercats.com
17Mark71 is offline
post #2 of 4 (permalink) Old 10-17-2015, 07:19 PM
skinnytick's Avatar
Nothing special, just tell them to align it.
If you want, you can tell them to use these "aggressive handling" alignment specs.
http://www.tccoa.com/articles/suspen...ent/index.html
BTW, where'd you get the Vogtland springs? Are they the 3/4" or 1.6" springs?
I feel every bump with my Tokico springs so I'm thinking about trying progressive rate springs.
skinnytick is offline
post #3 of 4 (permalink) Old 10-17-2015, 07:41 PM
Those alignment specs are wonderful; the last place I used didn't want to use them, so I no longer use that place, lol.
They're inside the factory specs, but toward an edge, so Not where anyone will usually set them without guidance.
post #4 of 4 (permalink) Old 10-17-2015, 07:52 PM Thread Starter
17Mark71's Avatar
3/4 drop. They were a TCCOA group purchase from a few years ago.
Thanks for the info.
300RWHP 335RWTQ
17Mark71 is offline
