Blown power steering line - TCCoA Forums
post #1 of 14 (permalink) Old 10-24-2015, 11:45 PM Thread Starter
David_viny's Avatar
So I blew a power steering line, the one from the pump to rack (rust). Now looking at the rack side, how on earth am I supposed to disconnect that fitting? Do I need to drop the k-member / pull the motor lol?
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #2 of 14 (permalink) Old 10-25-2015, 12:59 AM
It helps to have a short ... 18mm IIRC ... stubby open end wrench.
I also found knowing Klingon profanity helped ME *grins*
Fuelly
RalphP is offline
post #3 of 14 (permalink) Old 10-25-2015, 06:32 AM
MaddMartigan's Avatar
I'm pretty sure that a blown power steering line essentially means that the car is totalled and that you should just have it towed to the salvage yard.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #4 of 14 (permalink) Old 10-25-2015, 08:28 AM
Stubby wrench. Possibly lowering the subframe for better access. A lift. A lot of patience. A high tolerance for frustration.
I just had a whole rack done. Unless you have a lift the hose connections at the rack are supposed to be a real pain. As much as we like doing our own work this might be something to farm out to a pro.
97CatMan is offline
post #5 of 14 (permalink) Old 10-25-2015, 08:49 AM Thread Starter
David_viny's Avatar
Unfortunately this is a real consideration...
post #6 of 14 (permalink) Old 10-25-2015, 09:25 AM
Don't sweat it, it's not that bad. The fitting that comes out of the rack probably doesn't need to be changed. Just the hose and it's not a lot of fun but be patient and changing it won't be that bad.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 14 (permalink) Old 10-25-2015, 11:21 AM
You can buy the factory hose, or,
http://forums.tccoa.com/992-suspensi...ring-line.html
Fuelly
RalphP is offline
post #8 of 14 (permalink) Old 10-25-2015, 11:44 AM
The steering rack is one of the few bits I'd pay someone to do.
Just make them do it for book hours, lol.
(It's a 2 hour job in the book, iirc; well worth it.)
I had success by using two crow's foot adapters on extensions, but YMMV. My hands really don't fit there.
It is Definitely one of those Jobs to do while the engine is out.
Grog6 is online now
post #9 of 14 (permalink) Old 10-25-2015, 12:05 PM
Urambo Tauro's Avatar
The power steering line directly underneath my oil pan had developed a hole in it from rubbing against the battery cable down there. After repairing the cable, I tried to patch the PS line with J-B Weld, but that was a complete waste of time. So I cleaned it back up and took a small piece of high-pressure hydraulic hose, cut a slit in it lengthwise, and slipped it over the line. I then rotated it so the slit was on the opposite side of the line from the hole. I tightened it down with two small hose clamps, and that seems to hold okay.
Urambo Tauro is offline
post #10 of 14 (permalink) Old 10-25-2015, 01:35 PM
I found that entire move to convert as a complete waste of time. I leaked constantly and a lot of research turned up that you shouldn't use traditional SS braided hose for this purpose.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #11 of 14 (permalink) Old 10-25-2015, 02:25 PM
You're not supposed to use traditional SS braided hose, the writeup specifically says to use a high pressure hose, which are rated up to 2500 PSI, well above the max pressure the power steering pump generates
Aeroquip TFE Racing Hose FCC0603 - Free Shipping on Orders Over $99 at Summit Racing
post #12 of 14 (permalink) Old 10-25-2015, 02:32 PM
I'll go with you on that part but the leaks I suffered were all at the fittings. I would definitely look at doing this once we can't get new hoses but right now that's not the case.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #13 of 14 (permalink) Old 10-25-2015, 09:08 PM Thread Starter
David_viny's Avatar
Well I looked at it again... I see where one could possibly use cut down wrenches near the oil filter area, but still there is very little room. Add rust and my luck and I for see problems lol.
Got me thinking tho, how hard would it be to drop the subframe? Even though that sounds a little drastic, it might be easier in a way.
Looks like if I unbolted / disconnected the power steering lines, steering shaft, motor mounts, bottom shock bolts, and lower ball joint to spindle connection that I could just drop the whole thing??
Would obviously hold the motor up with a bar across the shock towers and chains or something.
post #14 of 14 (permalink) Old 10-25-2015, 09:26 PM
Matt5991's Avatar
I just replaced the whole rack on my car last week. it takes a little bit of doing but mostly because the bolts are so tight. if you have access to a torch to heat the nuts on the rack through the subframe it will be relatively pain free to just pull the rack out a bit to repair it. It really helps to have a lift for it but I suppose it could be done on the ground. Once those bolts are off you can pull the rack forward a bit and access the lines at that point, it makes it substantially easier
2004 Ford F250 250K Miles
1994 Thunderbird LX 196k Miles
1990 Lincoln Mark VII LSC SE (5.8/ T5 swapped) 205K Miles
1989 Lincoln Mark VII LSC 154K miles (Waiting for paint job)
197? Ford Circle Track Dirt Car (Thunderbird Nose, Mark VII body, 400 Engine)
Matt5991 is offline
