Cobra vs Thunderbird rear bearings and seals - TCCoA Forums
post #1 of 13 (permalink) Old 11-05-2015, 04:46 PM Thread Starter
coggonobrien's Avatar
I need to throw new bearings in my 94 hub swapped tbird. Are the bearings and seals the same for a 94 tbird vs the 99 mustang cobra? If someone has a list of Timken parts that would be awesome.
David
coggonobrien is offline
post #2 of 13 (permalink) Old 11-05-2015, 05:03 PM
Bearings are the same. There are no seals for the rear wheel bearings, just the hub on one side and the axle on the other.
post #3 of 13 (permalink) Old 11-05-2015, 05:33 PM
It's Timken "Set49" on RA, Amazon, and others.
Grog6 is online now
post #4 of 13 (permalink) Old 11-05-2015, 06:20 PM Thread Starter
Anybody have a rear spindle nut part#?
post #5 of 13 (permalink) Old 11-06-2015, 06:21 AM
jco1385's Avatar
The axle nut is 36mm and is p/n FOSZ-4B477-A.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #6 of 13 (permalink) Old 11-06-2015, 06:43 AM Thread Starter
Thank you all for the help
post #7 of 13 (permalink) Old 11-08-2015, 11:22 AM
fast Ed's Avatar
The hub nut number changed this year, it's now a hardware number W707772-S441. Used originally on the newer Expeditions and Navigators, it's a Nylock style nut now rather than the captive stack style.
cheers
Ed
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #8 of 13 (permalink) Old 11-09-2015, 06:50 AM Thread Starter
Thanks Ed, I'm guessing my failure was probably due to over torqueing. Do you guys use a torque wrench to set them?
post #9 of 13 (permalink) Old 11-09-2015, 07:39 AM
Nope, I just crank it down with the impact, and I have never had an issue.
post #10 of 13 (permalink) Old 11-09-2015, 02:17 PM Thread Starter
Thanks Mikey
post #11 of 13 (permalink) Old 11-09-2015, 04:17 PM
Roll the wheel as you tighten it; the bolt sets the preload on the bearings.
It'll move a bit if you do it right.
I usually stand on it; that's better than my impact.
Grog6 is online now
post #12 of 13 (permalink) Old 11-09-2015, 04:38 PM Thread Starter
You torque it with your wheel on or are you talking roll the hub
post #13 of 13 (permalink) Old 11-09-2015, 07:16 PM
Yeah, usually at that point I have the wheels on; the weight needs to be on them to tighten the suspension bolts, unless you want it jacked up in the rear for a while.
If you spin the bearing as you tighten it up, the center of it will fully seat between the hub and nose of the axle.
The axle slides the bearing inner on the hub as you tighten it down, until everything is tight.
If it doesn't tighten up together and take a preload, it will be wasted in 6 months or so.
On another note, I hope you checked them for grease; the last few I've gotten have been 50/50, None of the Koyo's had grease.
Grog6 is online now
