random loss of power steering - TCCoA Forums
post #1 of 9 (permalink) Old 02-23-2016, 12:53 PM Thread Starter
coggonobrien's Avatar
I've noticed some spuratic losses of power steering so far just at low speeds. Is it the power steering pump or something else?
David
coggonobrien is offline
post #2 of 9 (permalink) Old 02-23-2016, 01:17 PM
jco1385's Avatar
Does your car have the EVO variable assist steering? There is a valve on the high pressure line at the pump and a box under the rear deck for it. Maybe one of them is malfunctioning. How is the fluid?
If you unplug the harness from the valve at the pump, it should go full assist. This may help you troubleshoot.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #3 of 9 (permalink) Old 02-23-2016, 01:44 PM Thread Starter
fluid is full, belt is good. I thought all the car's had the variable assist. Mine is a 95 lx 4.6
post #4 of 9 (permalink) Old 04-21-2016, 11:42 AM Thread Starter
So I've noticed it gets hard to steer when the windshield wipers are running, turn the wipers off and it's fine.
post #5 of 9 (permalink) Old 04-21-2016, 01:29 PM
jco1385's Avatar
Have your alternator load tested.
jco1385 is offline
post #6 of 9 (permalink) Old 04-21-2016, 01:29 PM Thread Starter
ok, guess I should swap it as a I have a low mile spare on the shelf.
post #7 of 9 (permalink) Old 04-21-2016, 01:36 PM Thread Starter
I also only have high speed with the wipers (slow, intermittent and home currently do not work).
post #8 of 9 (permalink) Old 04-21-2016, 03:26 PM
T6Rocket's Avatar
That sounds like the multi-function switch (turn signal stalk). Hopefully you can still get it from Ford, not too hard to install.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #9 of 9 (permalink) Old 04-21-2016, 03:31 PM Thread Starter
i tried a doorman stalk and it made no difference, looking into the rest of the wiring since the dash was swapped.
