need help finding rear upper control arm bushings - TCCoA Forums
 1Likes
  • 1 Post By jco1385
post #1 of 10 (permalink) Old 02-25-2016, 08:21 AM Thread Starter
I have a 94 Lincoln Mark viii and the rear upper control arm bushing that adjusts camber is shot, and I figure while I have the arm out I'd replace the one that attaches to the knuckle to. I see them listed for the cougar and Thunderbird but not The Mark are they the same? Also is there a reliable source for the camber bushings, I've heard of them being misdesigned and its like a luck of the draw.
93mark8rules is offline
post #2 of 10 (permalink) Old 02-25-2016, 11:02 AM
It's the same spindle and upper control arm bushings as the MN12, yes. There's a sticky (the "Public Service Announcement" one) in the Suspension subforum (hey, the one we're in!) that describes the change.
Fuelly
RalphP is offline
post #3 of 10 (permalink) Old 02-25-2016, 12:40 PM
jco1385's Avatar
https://www.supercoupeperformance.co...-mark-viii-536
That is the cheapest place I've found for the correct upper/inner bushing. Shipping is free when you order 2.
Woodman likes this.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #4 of 10 (permalink) Old 02-25-2016, 09:25 PM Thread Starter
Ok I ordered the camber bushings from SCP today 80 bucks isn't terrible. But he was telling me that the bushing that goes on the end by the knuckle isn't available from anyone. He said the only option is Delrin or Poly and the poly are closer to stock but they're $180. Im not racing the car or doing any corner carving, I just cruise it. Is there anywhere to get them? If the spindles are the same why cant I use Cougar or Thunderbird parts? I think Pep Boys actually carries them. I think they're MOOG Part Number K8588?
I looked at the sticky about bushings but it refers to someone named Doug who Im guessing has passed away because it says RIP after his name ever time.
Also in the sticky I read something about Energy Suspension making bushings I found them listed for the Thunderbird theyre Part# 4.3163G
would these work?
post #5 of 10 (permalink) Old 02-25-2016, 09:49 PM
Well, DLF died - but Jay Richmond (98Mark8LSC here; Jay Richmond on Facebook) took it over.
Since the spindles are the same, yes, the MN12 (Tbird/Cougar) bushings will fit.
Fuelly
RalphP is offline
post #6 of 10 (permalink) Old 02-26-2016, 01:59 AM
MerkCougar's Avatar
I just recently ordered the upper and inner bushings from SCP and have not one complaint. Then again I also replaced every lower and upper rear control arm with poly bushings except for the ones aforementioned in this post.
MerkCougar is offline
post #7 of 10 (permalink) Old 02-26-2016, 06:42 AM
Knuckle bushings are NOT $180. Get them here for less than a quarter of that.
http://www.amazon.com/dp/B00EZ7K5OA/...40_TE_3p_dp_i1
post #8 of 10 (permalink) Old 02-26-2016, 01:41 PM
Amazon.com: Energy Suspension 4.3163G Control Arm Bushing Set: Automotive
Nice to know the lower knuckle bushings are available fairly cheaply. I think I would stick with the OEM type top knuckle bushing, though. Seems like that combo would minimize potential for squeaks and reduced ride quality.
Steve
S_Mazza is offline
post #9 of 10 (permalink) Old 02-26-2016, 05:20 PM Thread Starter
Thats awesome thank you. I wasnt sure if the Mark used some kind of special bushing. Its odd all the parts vendors treat it as if it was a totally different car from the T Bird Or Cougar. Also Energy Suspension only lists it on their web page for the T-Bird.
Do you know what size the nut is that holds the axle shaft to the hub?
I replaced a knuckle on my first Mark almost 11 years ago. If I remember right the knuckle is held in with torx, but was a real PITA to get in and out. I just dont remember why. Any tips or info guys?
post #10 of 10 (permalink) Old 02-26-2016, 06:58 PM
Info on the removal:
Super Coupe Club of America
I think the Mark bolts are harder to remove because the LCAs are aluminum, and the tabs are thicker. So less clearance.
Steve
S_Mazza is offline
