My Second Mod: Suspension Rebuild - Page 6 - TCCoA Forums
 68Likes
post #151 of 174 (permalink) Old 11-20-2018, 10:17 PM Thread Starter
CDsDontBurn's Avatar
Originally Posted by MaddMartigan View Post
The procedure for the Bilsteins is exactly the same. If you could do the Konis then you could also do the Bilsteins.
I understand that.
My problem is with the strut mounts. I had to get those spherical bearings for them.
Though, the Konis (8610 1437RACE) are appearing to be more difficult because they don't have a stud or thread at the bottom of the insert to secure them to the bottom of the sacrificial OEM strut body. Unless we've decided to go with those Konis for the Porsche now, 8611-1257 instead? The other new thing with the Koni units vs the Bilsteins is that the piston diameter is likely different and thus, the spherical bearings are now going to be different. These are the things that I cannot work out myself.
CDsDontBurn is offline
post #152 of 174 (permalink) Old 11-21-2018, 05:49 AM
MaddMartigan's Avatar
Originally Posted by CDsDontBurn View Post
I understand that.
Hang in there. We'll figure it out. Again, let's wait for the Bilsteins since they are a known quantity.
Grog6 and CDsDontBurn like this.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #153 of 174 (permalink) Old 11-21-2018, 10:21 AM
I was really pointing up options just in case the Bilsteins are actually disco.
If they make some more this spring, that's great.
If not, we at least saw pix of what's going to be required to use something else.
I can't believe Koni sells 50 sets of Porsche 944 shocks a year, tho.
Maybe there's that many track cars, idk.
Grog6 is online now
post #154 of 174 (permalink) Old 11-21-2018, 01:27 PM
S4gunn's Avatar
FWIW, I think the lemons community has done their part to empty out the inventory of the bottom feeder 944s on the west coast.
Those things are pretty glorious to see when the run but seem to die.. a lot.
The most practical example was a team who decided that they had enough of the engine/transaxle drama and said fuck it, we'll just drop in a Chevy 350 in. Glorious.
As far as this project is concerned, I'd suggest that CDsdontburn read the thread in which I compiled all the front suspension options again.
1) You don't need the monoball bearings in the top. That was a bit of silliness I went along with because if it's good enough for a Porsche GT3, there's no reason our tbird can't have them too. a tube and a washer (MaddMartigan's first design) will work just fine. The key is that you just need a hole at the top to fit the larger bilstein/koni shaft.
2) As far as the QA1 setup is concerned, the springs are cheap if you want to experiment. Like $30-60/pair cheap. As far as bumpstops are concerned, they are just rubber. IIRC. the Bilsteins have internal bumpstops. If you don't trust them and don't want to spend $14, you could make them out of any hard rubber. My engine mounts used to be hockey pucks. If you know someone who's kid is into hockey, you can always get these for free. a bumpstop is a hockey puck trimmed down to a smaller diameter + a bigger hole in the center.
2.5) As far as replicating the QA1 setup is concerned, I'm all for the experimentation. For the flanges on the bottom though you really do need three pieces of metal welded together vs just a flat sheet bent into a U. One thought is to cut down the donor shock so much that you just have the bottom flange + a small tube on top. A setup like this would drop into the small tube and you'd bolt it to the sides. I personally would find this a little sketchy but it's very similar to what tbirdtess did with a Bilstein circle track shock years ago.
https://www.summitracing.com/parts/q...8500/overview/
3) Getting the bilsteins lathed down is really no big deal even if you don't have a lathe. I dont. The key is to find a classic machine shop (not one full of CNC machines but the kind that's kinda dirty with some old dude), show up with the donor shock cut down with the bottom hole already drilled out in one hand + the bilsteins in your backpack and a six pack of beer in the other. Measurements? We don't need measurements. "Excuse me, sir. I want THIS to fit in THAT. Are you thirsty?"
Boom. The person puts the new shocks in the lathe and just start shaving it down. Cry a little as the pretty yellow outside goes away. 5 min later, you drink a beer and maybe give him/her a few more bucks. It helps if its like the late afternoon on a Fri.
http://goo.gl/csaet4
S4gunn is offline
post #155 of 174 (permalink) Old 11-21-2018, 01:29 PM
S4gunn's Avatar
Here's one more solution for those with more money than patience.
https://www.truechoicekoniracingserv...-touring-strut
NOTE: We will adapt an 8611 to your strut housing — Quoted price based on application. Please call for Details.
I can guarantee that the QA1 option will be cheaper.
Trunk Monkey likes this.
S4gunn is offline
post #156 of 174 (permalink) Old 11-21-2018, 06:07 PM Thread Starter
Sent Bilstein another email about any possibility of the 3000GT inserts being pushed back further. They said it's possible.
9:20 AM (10 minutes ago)
to me
Hello Jonathan,
This is just an estimated time of arrival. There can be a possibility that the dates will change.
Thank you,
Mit freundlichen Grüßen / Best regards
Bryant Vuong
I also sent Koni another email asking them if they make inserts for the Mitsubishi 3000GT, they don't.
On Wed, Nov 21, 2018 at 5:49 AM info.koni.us, wrote:
Jonathan,
The 8611 1257race is a double adjustable strut cartridge just like the 8610 1437race, but much shorter. It is not a cut-a-strut and does not have the threads at the bottom. Also, we do not offer an application for the 3000GT. We have researched this in years past, and unfortunately we do not have a good off the shelf cut-a-strut option for the Thunderbird. The best options are to either find a used set of the Thunderbird specific dampers and have the serviced/rebuilt or use the 8610 1437race in a custom housing.
I asked about the 3000GT because, well, it's what we're trying to use from Bilstein so I thought it'd be good to ask if Koni had anything for that platform. I also asked about the 944 platform because it was brought up here. Instead, he already gave me information we already know that is related to the MN12 platform with Koni products when I was asking about information for other potential inserts to use for the MN12 platform.
I'll hang. I've got some time to go anyway before the car is back up. I still need the transmission. That said, with the above emails, I'll hold on to my order with Summit for the Bilsteins until end of March....or until you are done with your build, whichever is first, lol. If Koni is the end resulting insert, then it looks like I'll end up going with the 8610-1437RACE units. Though, if there is another unit that grabs my attention from another manufacturer, I'll reach out to them and see if it will work.
So...KYB, Tien (they may have something for the 3000GT since they do more stuff for imports), and...? Any others that have an aftermarket support presence?
I did go through your thread again, and based on what low key "generic" struts for your racing you used, I want to use the same ones based on your feedback on them. I saw other Koni PNs you put in there as well and I'll also consider them if Bilsteins are in fact no-more.
If the Bilsteins state they don't need bumpstops, I won't get them. If they need them and don't come with them, I'll get them separately. I'm not going to cry over $14.
Only people I know who are into hockey, is my wife's dad and his family. They're in Buffalo, NY area though. Not very convenient for me...
That is seriously a "fork" type design. I was actually thinking of drawing something up exactly like you said. The tube up top would then be secured to the strut via a nut and screw type. This is the fork that my 6th Gen Honda Accord uses. Of course, it wouldn't be looking exactly like that, but a similar type setup.
With me being Latino, I know shops. LOL. A 12 pack of Corona, Modelo, or Tecate and $20 later, it can be done.
I have more patience than money, lol.
post #157 of 174 (permalink) Old 11-21-2018, 07:16 PM
I can't see the vehicle specific BS they're pushing.
A 3800lb car is a 3800lb car, what exactly is different?
I am not a Mech E, but damn, weight, inertia, and travel is it.
Am I missing something?
Grog6 is online now
post #158 of 174 (permalink) Old 11-21-2018, 10:43 PM Thread Starter
What's exactly different? Girth of the insert tube, length of the piston shaft (rod?), and travel of the piston are my guesses.
post #159 of 174 (permalink) Old 11-26-2018, 03:52 PM
S4gunn's Avatar
Here's something I found this weekend.
http://info.bilsteinus.com/public_ac...ay%202018.xlsx
Filter "Suspension strut cartridge", B6 series (two checkboxes), 22.45" length (same as 3000GT which we know works),
Here's what I found.
34-050231 Suspension Strut Cartridge B6 Performance Nissan / Infiniti Nissan 240SX 1994-1989 Weight 4.96LB
34-003527 Suspension Strut Cartridge B6 Performance Toyota Toyota Celica 1993-1990 Weight 3.79LB
34-001370 Suspension Strut Cartridge B6 Performance Audi / Volkswagen Volkswagen Cabriolet 1993-1985, Jetta 1984-1980, Rabbit 1984-1975, Rabbit Convertible 1984-1980, Scirocco 1988-1975 Weight 4.63LB
34-050224 Suspension Strut Cartridge B6 Performance Eagle / Mitsubishi Mitsubishi 3000GT 1999-1991 Front Without Electronic Suspension MITSUBISHI 3000GT;F;B6 $243.10 C 651860649306 2.95 2.95 22.45 Weight 4.85
It seems like the 240SX strut is the most likely candidate for an alternative Bilstein strut 34-050231. Its similar weight so it should be similarly beefy
It's also a 36mm monotube insert (same as the Mistu 3000GT)
Ship date from Bilstein is in December (seems to be backordered with none in the US)
Only downside is that an S13 is 2700LB with 1485LB on the nose (55/45 weight distribution)
3000GT is 3800LB w/ ~2204LB on the nose (58/42 weight distribution)
V8 Tbird is 3700LB w/ 2183LB on the nose (59/41 weight distribution).
That is a pretty significant delta and explains why the 3000GT is probably the best fit from a dampener/valving standpoint.
S4gunn is offline
post #160 of 174 (permalink) Old 11-26-2018, 04:33 PM
The Koni part number for the 1989-1994 Nissan 240SX is "8641 1364Sport". It's a "Cut a Strut" and, based on what actual pictures I can find, a bolt through the bottom model. I can only assume that it has the same physical dimensions as the Bilsteins. However, like you said, it's for a much lighter car.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #161 of 174 (permalink) Old 12-04-2018, 12:27 AM Thread Starter
Update:
I haven't contacted any other vendors or manufacturers since we left off on this. However, tonight I logged into my account with Summit to see if I can get some parts for my daily. Out of curiosity, I went to my order status to check on the order and now they've changed it to February 8, 2019! After that back and forth with Bilstein, I somewhat expected this to happen. But the fact that Summit is now in line with Bilstein makes me happy.
MaddMartigan and Trunk Monkey like this.
post #162 of 174 (permalink) Old 01-04-2019, 09:20 PM
Well, I'm happy to see this day getting closer; My Tokicos are making noise now.
I'm going to go out and crawl around tomorrow, and see if any are leaking.
I have a virgin set of sports ready to go on.
I bet Bilstein will be happy they mode "One More Set"; I'd say we have close to 10 orders here.
Grog6 is online now
post #163 of 174 (permalink) Old 01-05-2019, 01:25 AM Thread Starter
And that's just for us MN12 guys doing this Bilstein insert mod. I wonder how many GT3000 people are set on buying a set of these for their car?
I'm thinking of getting a second set of these Bilsteins specifically because of unobtanium.....
post #164 of 174 (permalink) Old 01-05-2019, 07:24 AM
I really think I could make something else when needed. The whole QA1 thing from SuperCoupePerformance has inspired me.
CDsDontBurn likes this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #165 of 174 (permalink) Old 01-07-2019, 10:43 PM
heavy fork idea
why not pop the lower bushing out and make a new lower mount. them lower cast forks from other cars are just adding weight to the car. With the different lower mount it can possibly open up better and newer shock avenues.
REGULATOR is offline
post #166 of 174 (permalink) Old 01-07-2019, 11:27 PM Thread Starter
The problem with a fork idea (while great) is that it doesn't solve the part of where the spring would be installed to.
The insert idea is basically using the OEM strut to house the insert whilst the oem strut is still used for spring perch so the spring can still be supported.
post #167 of 174 (permalink) Old 01-07-2019, 11:43 PM
I see the OEM housing/new insert as a problem in itself if the inserts cant be found. I'm thinking that the idea of adapting a new assembly from a different and popular vehicle is more feasible.
post #168 of 174 (permalink) Old 01-07-2019, 11:50 PM Thread Starter
Oh, I wholeheartedly agree with you on that. If supply is unobtainium, then something else must be created for us enthusiasts. @MaddMartigan has already stated that he's got something in mind to attempt to bring about a resolution using a different adaptation inspired by the QA1 coilover setup.
post #169 of 174 (permalink) Old 01-08-2019, 12:38 AM
I'm thinking the 93-02 camaro/firebird with different mounts is a good possibility.
post #170 of 174 (permalink) Old 01-08-2019, 05:25 AM
Honestly, I can see building a configuration where a bottom mount is made to work like it currently does but it becomes the spring perch. The shock you could use is the kind that has the T shape on the end and allows it to bolt directly to that mount/perch. This configuration could also allow a stock style top mount.
The biggest problems with all of these ideas is the overall shock travel, the length of the assembly, etc. When you start from scratch on the design you have to start taking all kinds of measurements and start doing a lot of custom fabrication. That might be OK for me since I would be willing to do it one time for myself but I can't see doing it more than once. I'm not a professional by any stretch and I don't have professional tools. The benefits of taking the kind of route we've taken is that it reuses a lot of the stock parts and design so that you only have to worry about the damper and not everything else.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #171 of 174 (permalink) Old 02-28-2019, 06:09 PM Thread Starter
So February 8th came and went, and they pushed my ETA to March 6. It's not even March yet, and my order has been pushed back to April 1st .
post #172 of 174 (permalink) Old 02-28-2019, 07:56 PM
In addition to the like button, we need a "That Sucks!" button.
Ain't no way I'm likin' that!
Grog6 is online now
post #173 of 174 (permalink) Old 02-28-2019, 08:45 PM
It's actually my fault. I need to finish my project before I start on his so I ask Bilstein to hold off on shipping this stuff.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #174 of 174 (permalink) Old 03-01-2019, 10:47 AM Thread Starter
lol
