After I got my T-Bird running last week, I noticed that there was a rattling coming from the front. I was told to lift the front, grab the wheels at 12 and 6 o'clock and shake it to see if it moved / wiggled. The fronts were fine so I moved to the rear. Upon doing the same for the rear driver, it moved and likewise for the passenger rear. This obviously means that I have failed rear hubs which will need replacement. This being a safety issue, I've decided to go ahead and start rebuilding the suspension over the transmission. The transmission just leaks but shifts fine otherwise and I have to add some ATF to it every so often which I can live with for the time being.
All this being said, I've begun doing some searching here in the suspension section of the forum and have found a ton of info. Posting on the FB TCCoA group, I was told by Woodman (Durwood) to go ahead and do all the knuckle bushings since I'll already be there anyways. He's even provided me the link to Energy Suspension for the correct bushings. They're inexpensive, so I'll definitely be doing this. The video I found (below) on YouTube pretty much spells out how to do the job, minus how to put the new hubs on, this job seems to be something I can do in an afternoon. This post by jco1385 (pictures in the quote) makes it seem that I can do press the hubs in myself provided I have the right tools.
As far as parts go, I've heard from several people and read in a few threads already that Timken is the way to go in terms of hubs. There has been one person mention a brand called SKF for hubs. Any thoughts on Timken vs SKF?
Now that I've mentioned this, I will have to say that the suspension will most definitely take me a long time to get it to where I want it to be at. The rear hubs being replaced is basically my starting point on all this. I'm going to be doing more reading and research on the matter, and of course asking here as questions from me come along.
