Well, this explains why my old tires were so bad... - TCCoA Forums
 1Likes
  • 1 Post By Grog6
post #1 of 3 (permalink) Old 03-25-2016, 10:05 PM Thread Starter
Woodman's Avatar
So as you guys know, I recently got new wheels/tires, took it to get an alignment, and found out I needed new tie rods, front hubs, rear upper control arm bushings, and rear knuckle bushings.
I got all that replaced, and got it in to be aligned today (payday, woot!).
This is what the wheels were like. I know I am probably a little to do with the front alignment, but not much. I counted the turns on the tie rods and matched them up, they were very close.
Woodman is offline
post #2 of 3 (permalink) Old 03-26-2016, 10:11 AM
I've tried a dozen times to set these cars back after rebuilding everything; I've never done it successfully.
I quit trying, and just make an appointment to get it aligned afterwards now; it saves time and frustration.
BTW, setting it up with the numbers in the Article makes it drive Much better.
Woodman likes this.
Grog6 is online now
post #3 of 3 (permalink) Old 03-26-2016, 04:24 PM Thread Starter
Woodman's Avatar
Yeah, I know. I forgot to grab the document before I went to get it aligned. I tell you what though, it drives MUCH better than it did when I bought it.
I knew I'd need an alignment after doing the work, but it was already bad enough that you could see the toe out on the front wheels with it straight ahead.
Woodman is offline
