Lowered Strut suggestions - TCCoA Forums
post #1 of 4 (permalink) Old 05-22-2016, 09:43 AM Thread Starter
I'm sure this has been discussed extensively, but my searching is turning up blank....
I have a 97 Cougar with 1.5" Eibach lowering springs. I have been running KYB mono tubes all around. The ride was great when new, but seemed to have worn out quickly.
I'm looking for some suggestions here with the 1.5" drop. Thanks.
Kidd-7 is offline
post #2 of 4 (permalink) Old 05-22-2016, 10:05 AM
Woodman's Avatar
I have KYB GR-2's on my 1.5" Eibach lowered Thunerbird, combined with 1989 SC front and rear sway bars, and they seem to be holding up well.
The Tokiko Blues are very good, Bilsteins are better, I do not know if Koni makes anything that fits our front suspension, but you can only get rear Bilsteins for our cars, so people tend to mix Tokiko blues up front, Bilstein (from a 99-04 cobra) rear.
Me personally, when I need new shocks, I'm going with Tokiko blues. Good price/performance for a street driven fun car.
Woodman is offline
post #3 of 4 (permalink) Old 05-22-2016, 11:15 AM
Koni quit making shocks for our cars a while back; DLF and I both tried to order a set, and they were gone.
The Tokico blues are the best now available; unless you want to roll your own:
http://forums.tccoa.com/44-suspensio...om-design.html
http://forums.tccoa.com/44-suspensio...ew-shocks.html
Grog6 is online now
post #4 of 4 (permalink) Old 05-23-2016, 04:56 PM
ttbird's Avatar
Installing front Tokico blues on Vogtland 1.6'' . Does anybody know if I need to cut the Tokico bump stops?
92 Thunderbird Sport 04 Mach1 05 Mustang 77 F-250 460 Tow Pu 69 Mustang Fb wifes Drag car 64 Comet afx clone my Drag car
ttbird is offline
