Oh help, lol??? - TCCoA Forums
 1Likes
  • 1 Post By theterminator93
post #1 of 9 (permalink) Old 05-31-2016, 08:29 PM Thread Starter
Oh help, lol???
I got in my 97 Tbird and felt like i have a flat but no, faster i go the whole rear end seams to bounce. Also a note i did hit a rock last week in the front but this right sided rear thingy started tonight and i'm sick silly. Any clues????
unciet is offline
post #2 of 9 (permalink) Old 05-31-2016, 08:41 PM
I'd remove and inspect the tires/rims make sure you didn't throw a weight or bend anything. Ensure the tire is okay (no gouges, separating tread etc. and check just about anything else suspension-wise back there to make sure there's no obvious issues. Make sure all the bolts are tight and so forth.
unciet likes this.
post #3 of 9 (permalink) Old 05-31-2016, 08:53 PM Thread Starter
Will do those things Brandon...
unciet is offline
post #4 of 9 (permalink) Old 06-01-2016, 07:20 AM
Rayo's Avatar
Check your rear wheel bearings..
This video shows you how to check your rear wheel bearings, to see if they are bad or not..Skip to 1:30 of the video
1991 Ford Thunderbird Sport
Rayo is offline
post #5 of 9 (permalink) Old 06-01-2016, 08:34 AM Thread Starter
Seems the whole cars vibrates badly, kind of leaning towards an unbalanced drive shaft, could this be possible from hitting a rock plus I noticed the front sway bar is bent???
unciet is offline
post #6 of 9 (permalink) Old 06-01-2016, 09:23 AM Thread Starter
Just took the car for a ride and I swear it feels like the wheels are jumping up and down, now I'm totally lost??/
unciet is offline
post #7 of 9 (permalink) Old 06-01-2016, 03:02 PM
Driveshaft will cause a vibration but it's a higher frequency than a tire vibration - and is also a much lower amplitude.
Swap each tire out for the temporary spare (one at a time, of course lol) and take the car out for a quick spin at <50 MPH to see if any single tire is causing the issue.
post #8 of 9 (permalink) Old 06-01-2016, 04:05 PM Thread Starter
Shoot, I'm to chicken to go past 10mph. Put the car on blocks and put it in drive and that old drive shaft shook away and the right rear wheel has a small clicking.
unciet is offline
post #9 of 9 (permalink) Old 06-01-2016, 06:57 PM Thread Starter
I wanted to add with rear wheels off the ground, they are extremely hard to turn by hand
unciet is offline
