SCP Front CoilOvers - TCCoA Forums
 8Likes
  • 4 Post By Dumped96bird
  • 1 Post By Dumped96bird
  • 2 Post By Grog6
  • 1 Post By Grog6
post #1 of 15 (permalink) Old 06-26-2016, 03:27 PM Thread Starter
Dumped96bird's Avatar
SCP Front CoilOvers
SCP coilovers are the best suspension investment I've put into my car, I've run tokico blues ,kyb and these are the best if anyone wants true adjustment this is the only way to go
07 Civic SI Sedan-Daily
96 Thunderbird-Project
65 Mustang coupe-Project/Garage Art
http://www.1320addiction.com
Dumped96bird is offline
post #2 of 15 (permalink) Old 06-26-2016, 04:19 PM
That looks fantastic.
What color is that on your car exactly? Was thinking of getting my painted similar color next year.
It runs 100% of the time 80% of the time.
lurch is offline
post #3 of 15 (permalink) Old 06-26-2016, 08:35 PM Thread Starter
Not sure just the silver from 96
post #4 of 15 (permalink) Old 06-26-2016, 09:55 PM
sik97bird's Avatar
Interesting... hefty tag... did you have to buy your coil spring or did it come with it?
sik97bird is offline
post #5 of 15 (permalink) Old 06-27-2016, 08:57 AM
Thunderstruck95's Avatar
Did you get SCP's rear coil overs too? Or are you running a conventional spring out back? Also, did you consider getting the double adjustable setup, or did you figure the single adjustable would be good enough for what you wanted?
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #6 of 15 (permalink) Old 06-27-2016, 02:35 PM
jco1385's Avatar
Be careful with those polyurethane strut rod bushings. Car looks great!
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #7 of 15 (permalink) Old 06-27-2016, 02:40 PM
Car looks great! The lack of dust boot on the shock scares me far away from trusting those for driver duty though. Is the travel limited? The shock looks awfully shorter with that big upper mount
post #8 of 15 (permalink) Old 06-27-2016, 04:52 PM
Hi
is there a chance that you can post the dimension of the mounting brackets, these are the black pices, please
The shocks alone cost only 250 $ a pair,and 500 $ for just 4 brackets is pretty hefty .
what springs are you using ,specs please
any info is appreciated
so long
hoschy
Bad-Hoschy is offline
post #9 of 15 (permalink) Old 08-08-2016, 11:25 PM Thread Starter
Sorry for the delay been going threw some family stuff
Just the front single adjustable it's just a street car
Travel is good I've dailyed it every day sence I put them on
Originally Posted by Bad-Hoschy View Post
Hi
so long
hoschy
I run 10inch 450 pound springs 5 clicks from full stiff
If Bill from Scp wants that to be known he can post the specs
Thunderstruck95 likes this.
post #10 of 15 (permalink) Old 11-13-2018, 04:17 PM
I'm planning on pulling the trigger and ordering these. Does anyone else here have any direct experience with these coil overs? I think I want to go with the double adjustable version.
From what I gather, they seem to be similar to the group purchase ones discussed 8 years ago.
1995 T-Bird.
post #11 of 15 (permalink) Old 11-13-2018, 04:50 PM
CDsDontBurn's Avatar
OMG, that looks sexy as all hell!
It just sucks that they are cost prohibitive.
CDsDontBurn is offline
post #12 of 15 (permalink) Old 11-14-2018, 03:22 AM
You can add an adjustable perch to the modified bilsteins in the sticky, if you want. Id do that, as the shocks in the pic are known to be softer, even with the adjust all the way down.
There was a group buy here years ago; several people here had these at one time.
MaddMartigan and Trunk Monkey like this.
post #13 of 15 (permalink) Old 11-14-2018, 01:20 PM
Is there a Manufacturer and PN available for the adjustable perches? I'm curious to know what these look like.
post #14 of 15 (permalink) Old 11-14-2018, 03:08 PM
When you say this, do you mean that the QA1's are not as firm? When talking with Bill at SCP, he told me that even though they are 18 way adjustable, anything over 7 or 8 gets more firm than would be desirable for most drivers.
1995 T-Bird.
post #15 of 15 (permalink) Old 11-15-2018, 03:29 AM
Search for the threads; I can remember that very few people are still running them from the group buy.
The cost was even higher than the Konis, at the time.
You Can crank the konis up too stiff, even several years old.
Of course, they're not available.
I'm going the bilstein route; the sleeves and adjusters are available from summit racing, and others.
There's a thread here how to adapt the spring perches we have to the sleeves somewhere.
Looks like Bruce is running the ones you're looking at, I'd ask him what he thinks.
393 Thunderbird Under Construction, Coilovers
https://forums.tccoa.com/44-suspensi...er-fronts.html
https://www.tccoa.com/forums/44-susp...uspension.html
Here's the thread I remembered:
https://forums.tccoa.com/44-suspensi...coilovers.html
https://www.tccoa.com/forums/44-susp...over-woes.html
https://www.google.com/search?q=adju...ih=958#imgrc=_
CDsDontBurn likes this.
