Struts and Shocks - TCCoA Forums
post #1 of 4 (permalink) Old 08-13-2016, 05:04 AM Thread Starter
Struts and Shocks
Can I use Factory T-Bird Shocks and Struts on my 95 Lincoln Mark VIII.i NEED TO KNOW SOOON
eazezee is offline
post #2 of 4 (permalink) Old 08-13-2016, 07:03 AM
steamer471's Avatar
Yes. Do you have air ride now? If so you'll need a few things. The fronts will bolt right up. For the rears you will need an upper spring perch which usually comes with a kit you can purchase from Rock Auto and over the web. You'll also need to cut a wire or two for the air ride suspension to get rid of error messages. Plenty of articles on the web and a video on YouTube.
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #3 of 4 (permalink) Old 08-14-2016, 04:53 AM Thread Starter
Shock and Strut Swap
I done had one bad dealing with a mail order conversion kit and I plan on doing a more custom conversion.I been told more than once it will .But after this lil non fitting conversion kit I'll get through a local speed shop...just asking for a few ideas
Eazezee
eazezee is offline
post #4 of 4 (permalink) Old 08-14-2016, 11:36 PM Thread Starter
I did have the air ride that was bad on the car when I bought it along with the rest of the suspension that I've done replaced from top to bottom. And going over The T-Bird performance end is rather affordable. I also heard of using the Sc Bird for a lil more stiffer suspension and lowering...give ideas people for economy performance gains
Eazezee
eazezee is offline
