Please help identify part on rear suspension - TCCoA Forums
post #1 of 9 (permalink) Old 06-05-2017, 02:01 AM Thread Starter
First off i would like to give a big thanks to everyone in this forum, its great to have such a helpfull community. I recently bought a 92 tbird 5.0 ho and this forum was a huge help when i went to rebuild the front end, but now im working on the rear, and im stumped. im not a big suspension guy but it doesnt hurt to learn, and ive never had any issues with rear suspension parts in the past. I bought the car for 300 amd im already about 1200 into it. Anyways the part im needing is pictured below. Its basically rusted through. Thanks in advance.
Amos Hack is offline
post #3 of 9 (permalink) Old 06-05-2017, 06:09 AM
It's called a REAR SUB FRAME STABILIZER BRACKET. It's still available, right side and left side. There are 4 in all, are they all rusted out like that?
Bad news is, the bolts attaching it to the frame can be almost impossible to get out.
post #4 of 9 (permalink) Old 06-05-2017, 10:40 AM Thread Starter
Thanks a lot for the info, well if i can get it off i imagine ill have to replace the bolts, wonder what the part number on those is. If i cant get the bolts off then maybe i can put a jack on it and have it welded or is that a bad idea? How important is this piece? Maybe i should spray the underneith woth some under coat, its all rusted luckily this is the only piece thats rusted all the way through.
post #5 of 9 (permalink) Old 06-06-2017, 12:27 AM
Anywhere near Oregon? I have a complete rear end on a 92 5.0 that I won't need. Begin parting it in the next few months (I just want the 5.0 and stuff for a project). Could make a deal for sure if you were close enough...
scottjohnston is offline
post #6 of 9 (permalink) Old 06-06-2017, 05:14 AM
MaddMartigan's Avatar
Ebay BRAND-NEW-OEM-LH-REAR-SUB-FRAME-STABILIZER-BRACKET
Ebay BRAND-NEW-OEM-RH-REAR-SUB-FRAME-STABILIZER-BRACKET
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #7 of 9 (permalink) Old 06-06-2017, 10:18 AM Thread Starter
Im in ky 42701 pretty good ways away...
post #8 of 9 (permalink) Old 06-06-2017, 11:41 AM
Only problem with that is, you still have to unbolt your old one from the car.
post #9 of 9 (permalink) Old 06-06-2017, 01:23 PM
jco1385's Avatar
I can get bolts if needed.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
