Independent rear suspension - TCCoA Forums
post #1 of 13 (permalink) Old 10-05-2017, 07:51 PM Thread Starter
Red face Independent rear suspension
I am in the market for the Rear frame to body insulators on my 1995 Ford Thunderbird LX with a 4.6 engine. I have looked high and low Ford has discontinued the part, surprise surprise! I was hoping someone had an outlet as to anyone who could make me a set? The original part number was E9SZ 5D006A
40thTbird is offline
post #2 of 13 (permalink) Old 10-05-2017, 09:07 PM
They'll be UHMW (IIRC), but Jay Richmond ( 98Mark8LSC here, Jay Richmond on Facebook) makes some now.
Fuelly
RalphP is offline
post #3 of 13 (permalink) Old 10-06-2017, 07:39 PM Thread Starter
Thanks, Ill reachout to him
post #4 of 13 (permalink) Old 10-31-2017, 04:37 PM Thread Starter
Unfortunately, Jay wont return my calls. Do you know anyone else who manufactures them?
post #5 of 13 (permalink) Old 10-31-2017, 05:00 PM
Thunderstruck95's Avatar
Bummer that Jay is not getting back to you. I have been saving my pennys and wanting to get his full kit next year...
They are pricey- but Super Coupe Performance has some aluminum ones that they make-
https://www.supercoupeperformance.co...6-aluminum-852
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #6 of 13 (permalink) Old 10-31-2017, 05:13 PM
If you're willing to go poly instead the prothane Cobra ones work, and are quite cheap
post #7 of 13 (permalink) Old 10-31-2017, 05:34 PM
He is looking for the subframe mount bushings, not the diff mount bushings, so Cobra stuff won't work.
post #8 of 13 (permalink) Old 11-01-2017, 06:45 PM
Do any of you guys know the size of the bolts on the IRS bushings?
The ones it was recommended to cut to make it easier to yank; My bolts will not move, so...
I'd rather have some grade 12.9 bolts (and nuts, jic) sitting here when I do this.
Also, Any difference in a mark IRS frame?
I know the diff case is aluminum, as well as the lower arms, but isn't everything else the same?
I'm going to go scout the JY, since the snakes are sleeping now.
post #9 of 13 (permalink) Old 11-02-2017, 08:19 PM Thread Starter
The original bolts were a 12 X 1.75 X 129.5 Metric bolt FYI
post #10 of 13 (permalink) Old 01-13-2018, 06:55 AM Thread Starter
Still looking for the subframe mounting bushings anyone out there have any ideas or know of anyone who can manufacture? Ford is NO help at all!
post #11 of 13 (permalink) Old 01-13-2018, 08:24 AM
Wile E. Coyote Jr.'s Avatar
Besides what has been previously mentioned I dont think anything exists. The aluminum ones are a great upgrade if you are looking for handling but if you arent than they will be too harsh. I guess you could try the rear ones from a 1993 SHO but I havent heard of anyone else doing that yet so not sure if itll work.
First: Stacie, 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Second: Ellie, 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Third: 1997 Dodge Ram 1500, thirsty daily.
Fourth: 1990 Tbird SC, GT40 5.0 mated to m5r2, BBK long tubes, motor out the hood, drift car.
Wile E. Coyote Jr. is offline
post #12 of 13 (permalink) Old 01-13-2018, 09:18 AM
SHO ones look completely different, and won't work.
Honestly, if you want stock bushings, I think your only option is to swap the whole subframe out with a used one that has decent bushings in it, because even just pressing the bushings out of the subframe will destroy them.
post #13 of 13 (permalink) Old 01-13-2018, 10:18 PM
Irv
Irv's Avatar
Super Coupe Performance is your only readily accessible option at this point. They're not cheap and they will transmit a bit more vibration because they're solid aluminum, but good luck trying to find used OEM bushings in decent shape.
Irv is offline
