Rear Drag Racing Shocks - TCCoA Forums
 1Likes
  • 1 Post By Grog6
post #1 of 11 (permalink) Old 12-26-2018, 03:30 PM Thread Starter
r429460's Avatar
What brand (part number too) rear drag shocks are every one running?
Plus what did you have to do to adapt the non cougar/bird shock to fit your MN-12?
Thanks Rick
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #2 of 11 (permalink) Old 12-26-2018, 08:07 PM
The Cobra Bilsteins are plug and play. I run them with drag bags at about 5 to 10 psi in the Vogtland springs.
post #3 of 11 (permalink) Old 12-26-2018, 09:44 PM
Black_Cat's Avatar
I run KONI adjustables, they are amazing
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #4 of 11 (permalink) Old 12-27-2018, 07:18 AM Thread Starter
r429460's Avatar
Please be more specific.
Part numbers and applications, year, there are for the rear.
Thanks Rick
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #5 of 11 (permalink) Old 12-27-2018, 07:29 AM
MaddMartigan's Avatar
Thanks Rick
Koni 8041 1270Sport
They fit the 1999-2004 Mustang Cobra Convertible and therefore fit our car.
In fact, if you find a rear shock that fits the 1999-2004 Mustang Cobra Convertible then it will fit your MN12. There aren't a ton of choices but they will work.
The real question that would help us find what you're looking for is to understand what characteristics you want. Do you want a shock that's really stiff or one that's really soft?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #6 of 11 (permalink) Old 12-27-2018, 11:21 AM
Any 99-04 Cobra rear shock works, only difference with the convertible vs coupe shocks is the valving, they’re softer than the coupe ones.
post #7 of 11 (permalink) Old 12-27-2018, 03:07 PM Thread Starter
r429460's Avatar
What is available for the front, I'm looking for something like a 90/10?
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #8 of 11 (permalink) Old 12-27-2018, 03:31 PM
There is practically nothing available for the front. Supercoupe Performance sells QA1 front shocks but they are pricey.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #9 of 11 (permalink) Old 12-27-2018, 03:43 PM Thread Starter
r429460's Avatar
Thanks guys.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #10 of 11 (permalink) Old 12-27-2018, 04:37 PM
Thunderstruck95's Avatar
The ultimate rear drag shocks may be QA1 TS707 (single adjustable) or TD707 (double adjustable) for 99-04 Cobra.
https://www.summitracing.com/parts/qa1-ts707
https://www.summitracing.com/parts/qa1-td707
Quickly looking around online- these seem to be getting harder to acquire. Summit says 2 week lead time on the double adjustable but the single is in stock. Other places say 'no longer available' for either.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #11 of 11 (permalink) Old 12-27-2018, 05:48 PM
This is the best we have been able to work out, but there are many issues, the biggest of which is the availability of the Mitsu 3k inserts.
https://forums.tccoa.com/44-suspensi...nsert-diy.html
MaddMartigan has really outdid himself by making some custom parts; Begging MIGHT help, I can't speak for him.
He Is a Fab Artist, as I can attest.
If you can fab stuff, that will help considerably.
As a group, we're fucked as far as the front goes, over the counter.
Crap; I forgot about Bill, check the suspension section on SCP.
MaddMartigan likes this.
