Is poly available for front LCA to shock? - TCCoA Forums
post #1 of 4 (permalink) Old 01-02-2019, 04:42 PM Thread Starter
Thunderstruck95's Avatar
Maybe I'm blind, but I am not seeing any polyurethane options for where the shock bolts to the front LCA. Is there one available?
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #2 of 4 (permalink) Old 01-02-2019, 06:47 PM
CDsDontBurn's Avatar
That middle hole. As far as I'm aware, there are no poly bushings for that guy. Just OE replacements that I am aware of. Perhaps SCP may have some, but I doubt it as well.
CDsDontBurn is offline
post #3 of 4 (permalink) Old 01-02-2019, 07:04 PM
Why? That won’t improve anything about the car’s handling.
post #4 of 4 (permalink) Old 01-02-2019, 09:18 PM Thread Starter
With the factory style bushing, once the shock is torqued to the lower control arm, the only movement that would happen during suspension cycling would be the inner sleeve flexing in the molded rubber. Because of this, I never fully tighten these bolts unless the car was sitting close to ride height. With the factory arraignment of the steel shock there was no worries of excessive force.
The reason I am thinking about this is because I purchased SCP’s front QA1 coil-over setup. Looking at the picture, you can see that any any force from suspension cycling is directly on the end of the shock rod. I was hoping that a poly option would allow that inner sleeve to move freely and not transmit nearly as much twisting force on the rod.
I may be over thinking this... thoughts?
Now before anyone gives me too much flack for my decision to run these “inferior aluminum drag only” parts, lets let this current generation of coil-over prove them selves out. I have only seen one other person here running Bills coilovers, and he likes them. I wanted to give them a try as well. I’ll keep everyone posted with my experiences.
File Type: jpeg E3BB32AF-BE77-4F08-AB45-576B43343EC7.jpeg (1,021.1 KB, 0 views)
1995 T-Bird.
