rear suspension - TCCoA Forums
post #1 of 5 (permalink) Old 02-06-2019, 10:55 AM Thread Starter
jtavares0701's Avatar
rear suspension
so I have 2 tbirds both 95s but one has 3.8 other 4.6. The 4.6 is my daily and 3.8 a parts car. Does anyone know if the rear suspension parts are interchangeable? i know the brakes are different. i have some bad bushings banging around and just trying to take the cheap route for the time being. Im thinking about swapping over rear control arms if they're a match to gain good bushings.
jtavares0701 is offline
post #2 of 5 (permalink) Old 02-06-2019, 11:20 AM
Yes, those parts are identical
post #3 of 5 (permalink) Old 02-06-2019, 08:24 PM
Are there any good sources for aftermarket bushings that will last? Something like energy suspension?
Dave588 is offline
post #4 of 5 (permalink) Old 02-06-2019, 11:14 PM
Yes - and no.
Do a Google Search against the TCCoA forums for "Rear LCA bushings"; there's an Energy Suspension/Prothane set that can be coaxed to fit (but you get to toss about 1/2 the bushings in the kit out); Jay Richmond was making some Delrin bushings; I think Bill over at SuperCoupePerformance even has some Delrin bushings.
(I have a set to put in some Mark VIII LCAs for my Cougar; that's something to do this year.)
Fuelly
RalphP is offline
post #5 of 5 (permalink) Old 02-07-2019, 07:48 AM
T6Rocket's Avatar
If you're hearing a rattling noise, it's likely the sway bar end links. That is a common issue on these cars. It is also a pretty easy job.
If somehow it was the control arm bushings, be careful with that job since they hold the tension of the spring. It is a big job. So big, that my mechanic removed extra parts when swapping my springs just so he didn't have to touch those bushings. Probably didn't want to ruin them. That's another thing: they could get ruined anyway during the R&R.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
Similar Threads
Front Suspension Rebuild and SC Suspension Swap + Collision Repair Raptor22 Suspension 34 05-15-2010 12:39 PM
Is the XR7 Suspension and LX suspension the same? Josh Suspension 6 04-16-2005 12:25 AM
Rebuilding Front & Rear suspension, What should I replace? BlackTbird96 Suspension 11 12-18-2003 09:22 PM
cobra rear suspension jarends00 Tires/Wheels 13 06-17-2003 11:23 PM
Possible to convert rear suspension? Trinten Tires/Wheels 13 12-31-2002 06:50 PM
