Bolt sizes? front suspension - TCCoA Forums
 4Likes
  • 4 Post By jco1385
post #1 of 7 (permalink) Old 02-10-2019, 07:00 AM Thread Starter
RyanDudz's Avatar
Send a message via AIM to RyanDudz Send a message via MSN to RyanDudz
I'm going to be starting the process of replacing my front suspension. I know some of these bolts are going to be a PI TA to get off. I would rather just put new bolts in with the new ucas and lcas. What are the bolt sizes I would need to replace the shock mount bolt. UCA bolts exct..I'm having a hard time finding any part numbers or size information on this. Thanks for your help.
Ryan
RyanDudz is offline
post #2 of 7 (permalink) Old 02-10-2019, 10:32 AM
They are specialty bolts, you won’t be able to buy new ones. The only bolt that is ever a problem is the lower shock bolt, so try to get that out first. If that comes out, then the rest will be fine to remove and reuse. If the lower shock bolt needs to be cut out, then you will have to get a used set from someone on here.
post #3 of 7 (permalink) Old 02-12-2019, 07:30 PM
i agree with mad mikey probably best to just reuse them. If you need to get a new one I think that if you take a ruler and count the threads for every inch it will give you some info on the bolt specs. not sure if that's correct check with a hardware store maybe
97 lx (sport??) 'burd
sn95 hub swap (in progress)
cobra rear brake (parts needed)
flybirdyfly is offline
post #4 of 7 (permalink) Old 02-12-2019, 07:51 PM
dDUBb's Avatar
They are metric, specialty grade / with tangs on them, etc .. probably not going to find anything close to this at a hardware store.
dDUBb is offline
post #5 of 7 (permalink) Old 02-13-2019, 10:47 AM
jco1385's Avatar
If you need any bolts, let me know.
You won't find anything like these at Lowe's.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #6 of 7 (permalink) Old 02-13-2019, 04:02 PM
You Da Man JCO!
Nice to see someone here has spares that they're willing to share.
post #7 of 7 (permalink) Old 02-13-2019, 08:31 PM
You can go new.
N808998-S436 bolt.
N620604-S100 nut.
Similar Threads
17x9 tire sizes sizes fordfreak300 Tires/Wheels 37 02-25-2012 08:14 PM
Bolt Sizes for Engine Install FordofSin Engine - 5.0L & 5.8L 1 10-18-2008 07:31 PM
Bolt Sizes TBirdsRMachismo Exhaust 7 04-04-2007 05:09 PM
Bolt And nut head sizes Gary_C Suspension 3 01-23-2006 10:13 PM
Bolt Sizes? sfam198 General Tech 0 09-15-2005 11:12 AM
