Rear lower control arm to frame bushing - TCCoA Forums
 2Likes
  • 1 Post By Tbird Zak
  • 1 Post By CDsDontBurn
post #1 of 17 (permalink) Old 02-13-2019, 08:57 PM Thread Starter
Hi.
I am planning to replace the bushings in the rear and am stuck on the LCA bushings. I'm not really looking to put any delrin bushings as this is my daily and don't ever put it on the track. Is this the correct rear lower control arm to subframe bushing? Its the ACDELCO 45G11057 Professional: https://www.rockauto.com/en/moreinfo...0567&jsn=14101
I see it says Inner, which I do not know what it means. It appears rockauto doesn't sell a MOOG one either.
Thoughts? Thanks
95 T-Bird 4.6L Stock DD - 150k
Tbird Zak is offline
post #2 of 17 (permalink) Old 02-13-2019, 09:40 PM
You need this:
ACDELCO 45G11057 {#88912804} Professional
and
ACDELCO 45G9322 {#19186027} Professional
That's the LCA bushings, stock replacement.
You also need:
ACDELCO 45G26032 {#19187073} Professional
The Toe corrector.
You may also need:
ACDELCO 45G11001 {#88912749} Professional
It's the Inner Upper control arm bushing.
The Knuckle bushings are only available as Poly.
post #3 of 17 (permalink) Old 02-13-2019, 10:10 PM Thread Starter
Appreciate the info! Couple questions.
You need this:
Yeah that's what I was thinking. I'll need 4 of these.
These are for the front, no?
You may also need:
Are these equivalent to the MOOG K8562, in quality?
Have the Energy ones in my cart
post #4 of 17 (permalink) Old 02-13-2019, 11:56 PM
You may also need:
Actually, no. They work; the current Moog production are total crap (don't pivot right; there's a thread or twenty on them already, as well as on most parts.)
Fuelly
RalphP is offline
post #5 of 17 (permalink) Old 02-14-2019, 07:35 AM
T6Rocket's Avatar
Be careful with that job. I'm sure you know, the spring tension is held back by that control arm.
Out of curiosity, what makes you think those bushings are bad?
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #6 of 17 (permalink) Old 02-14-2019, 09:35 PM Thread Starter
Well that's good to know. Thanks!
Al
Yeah I learned that when putting on the lowering springs but I appreciate the heads up! I hear clunks all over the rear suspension when driving. I can raise up the back end and see all the play in the parts. I'm sure they've never been replaced since factory.
post #7 of 17 (permalink) Old 02-16-2019, 08:28 PM
Great meeting you & your friend yesterday Zak!
post #8 of 17 (permalink) Old 02-17-2019, 09:54 AM
T6Rocket's Avatar
Pretty much the only part that makes an audible sound is a bad sway bar end link.
Al
Previous Fords:
T6Rocket is offline
post #9 of 17 (permalink) Old 02-17-2019, 01:54 PM Thread Starter
Likewise Ron!
Al
The UCA to frame bushing makes a LOUD clunk. My sway bar links are relatively new too.
post #10 of 17 (permalink) Old 02-17-2019, 02:01 PM
The easy way to check that bushing is to put your foot on the top edge of the tire, and try to rock the car back and forth; when it gets to a certain point, you will hear it going clunk-clunk-clunk.
The rubber will have turned to powder, and exited the vehicle.
There's a post somewhere here where I replaced those.
post #11 of 17 (permalink) Old 02-18-2019, 08:24 PM Thread Starter
Yeah its shot.
As far as the rear sway bar bushings, RockAuto stocks the energy ones in black and red. Both say poly bushings, but the price is pretty different, $12 vs $20. Know of any differences?
post #12 of 17 (permalink) Old 02-19-2019, 02:52 PM
CDsDontBurn's Avatar
None, other than color.
CDsDontBurn is offline
post #13 of 17 (permalink) Old 03-07-2019, 07:29 PM Thread Starter
Thank you all for the help. Ordered the bushings. Going to install them over next couple of weeks.
CDsDontBurn likes this.
post #14 of 17 (permalink) Old 07-11-2019, 09:45 PM Thread Starter
So I finally got in there and disassembled the rear suspension. Looks like the UCA-to-frame bushings and toe compensators are completely shot, as well as some of the knuckle bushings. Ill be replacing all the knuckle bushings with the poly ones I ordered and will need to order toe compensators as I didn't expect those to be totally done.
The LCA-to-frame bushings (all 4) still seem to be good and firm, although slightly worn after 25 years. Is it worth replacing those? I mistakenly ordered 4 of those forward bushings tho, so I'd need to order 2 rearwards.
post #15 of 17 (permalink) Old 07-12-2019, 12:05 AM
Me being me, I'd replace everything that's been touched. Especially if it's 25yrs old....
RalphP likes this.
post #16 of 17 (permalink) Old Yesterday, 09:18 PM Thread Starter
How in the world did yall replace your LCA rearward and forward bushings?!
There's pretty much no way to get a receiver cup on the flange side which causes the C-clamp press to angle and not seat correctly! These bushings are a pain in the @$$. I saw two methods by other people:
1. Pressing out the rubber then cutting the outer shell in with like a sawzall
2. Grinding down the flange enough to either break it off to get the receiver cup to fit on then press out
There's got to be a better method, no? I rented the whole large bushing press kit from Advance. One way I found that might work is using only one of the receiver cups that seats like 90% flush and running a threaded bolt through the bushing fitted with some washers on the end and try to press it out that way.
Thoughts?
post #17 of 17 (permalink) Old Yesterday, 10:46 PM
Thoughts?
That should do it.
Since I'm going Delrin, I need to leave the cups in there; so I used the old torch-it-out method.
Fuelly
RalphP is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
wildturkey
Similar Threads
1989-1997 Ford Thunderbird Front Lower Control Arm & Ball Joints poly bushing mjf Parts For Sale 1 10-29-2018 05:52 AM
Front stabiliser arm - lower control arm bushes Andy625UK Suspension 6 01-31-2006 02:51 AM
lower control arm shock mount bushing mlbuxbaum Suspension 10 01-06-2005 04:25 PM
Lower control arm polyurethane bushing problem - won't press into control arms Kleckner Tires/Wheels 0 03-21-2003 03:01 PM
