Subframe removal to remove oil pan. - Page 2 - TCCoA Forums
 21Likes
post #31 of 35 (permalink) Old 03-03-2019, 03:41 AM
Removing the sub frame in this way, does ot affect the alignment?
Kidd-7 is offline
post #32 of 35 (permalink) Old 03-03-2019, 09:32 AM
Yes, it does; but if you put it back EXACTLY like it came out, it won't.
I'd still get the car 4-wheel aligned after I put it all back, though.
Fuelly
RalphP is online now
post #33 of 35 (permalink) Old 03-03-2019, 02:11 PM
There are alignment holes between the front pair of bolts on each side, place 3/4" tubes in the holes before you torque them down and you're set. Alignment will be fine unless the K member wasn't centered before.
post #34 of 35 (permalink) Old 03-03-2019, 04:21 PM
Remember the year (2017 IIRC) that it seems like EVERYBODY was retorquing the front subframe bolts?
Yah, I had to get mine realigned after that, because it wasn't quite 100% square.
So I'd bet that the subframe is currently not quite 100% square also in the OP's car.
So ... yah, I'd schedule an alignment, even with the dowels. Can't hurt it any.
Fuelly
post #35 of 35 (permalink) Old 04-07-2019, 02:43 PM Thread Starter
Doing it the way I mentioned with the longer bolts will not prevent alignment from being disturbed somehow, I did it this way mainly to make it easier on myself as I was working alone.
Not fighting the whole super-heavy behemoth while you lower it and while you try to keep it from sloping sideways and possibly hitting the floor or bending something is such a relief, same goes for putting it back on. I simply cannot think of a safer way to manage the whole task if you dont have a helping hand just as I didn't at the time.
I didn't have to realign the suspension as I was extra cautious to make marks on key parts to prevent them from moving around. Still, an alignement job is something I'd consider if my tires were new/expensive, mine are cheap and almost shot... and the car now behaves as it did and as it should (straight, no weird pulling sideways or crooked looking tires)
Turboedmav is offline
Similar Threads
DOHC Lincoln oil pan vs. mustang pan Thundernerd Engine - 4.6L & 5.4L 8 11-23-2006 11:01 AM
What size needed to remove subframe bolts? 94birdnj General Tech 11 09-17-2004 05:26 PM
oil pan removal??? DIABLO General Tech 5 11-24-2003 02:17 AM
Who has replaced their oil pan gasket or oil pump? Fastcat Engine - 5.0L & 5.8L 3 03-21-2003 04:08 PM
Engine subframe and oil pan removale Please Help lee Engine - 5.0L & 5.8L 4 12-24-2002 10:23 PM
