MK VIII LCA spring perches - Page 2 - TCCoA Forums
 20Likes
post #31 of 43 (permalink) Old 04-27-2019, 12:03 PM
Originally Posted by Zep5.0 View Post
Lol, true true. But if you could all go order a set, that'd be great, lol.
I plan to, when available.
I have been looking at alternatives, but they all seem to be on the same status.
There is apparently a Audi that uses either the B6 or B8 type shocks, and at least one of them has the forked bottom.
Grog6 is online now
post #32 of 43 (permalink) Old 04-27-2019, 01:22 PM
MaddMartigan's Avatar
I think this may be the example you mean:
Part # 24-066785
I haven't found the specs for it though. I also don't know how you would handle the spring either.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #33 of 43 (permalink) Old 04-27-2019, 01:35 PM
Part # 24-066785
I never thought to look at RA!
Yeah, I see what you mean; it's hard to weld a perch to a finished shock.
Aluminum coilover, somehow?
Grog6 is online now
post #34 of 43 (permalink) Old 04-27-2019, 02:41 PM
quickford's Avatar
We're going to have to act like hot rod guys and put Mustang II suspension under our cars
Current poor life choices: 1991 Mercury Cougar XR7, 1998 Lincoln Town Car, 2005 Ford Focus ST, 1997 Ford Probe GT.
Previously: 2015 Focus, 1996 Thunderbird, 1998 Taurus, 1989 Escort.
quickford is offline
post #35 of 43 (permalink) Old 04-27-2019, 03:02 PM
Part # 24-066785
I see some ears there for the lower spring mount; maybe a billet piece that bolts to that and holds the spring?
It'd be close to the design on my old 1967 Mustang ...
Fuelly
RalphP is offline
post #36 of 43 (permalink) Old 04-27-2019, 04:56 PM
CDsDontBurn's Avatar
Originally Posted by Woodman View Post
No one will have these until Bilstein makes more; it may not happen at all, based on my experiences with Koni.
It's not like they give a fuck about us, lol.
It's always a numbers thing. The cost to setup the tooling to make that type of insert has to have enough demand to make it worth the time/effort. If they can't make money off it, no sense doing it.
True, but with these Mitsu 3k inserts, their (Bilstein's) market has increased two fold: Mitsu 3k owners who want these, us MN12 peeps who want these. If there are enough people from both camps that want these, I bet Bilstein will make them.
I've looked at various front strut options for the Mitsu 3k platform and they seem to be just as limited as us. If between their group of people and us being enough of a demand to have Bilsteing make these inserts, they may just make them.
Now....to have some people over there get in on this action.....
If I knew what other options were available to us, RA would have been my first place to check on that platform for availability. Amazon would have been my second place to check.
Looking at that picture though, and if that one specific strut will work, perhaps grinding down that lip at the top half of the body so it can slide into our stock strut body as an insert? I'd imagine cutting off the bottom of our strut body as well as the top so that it just rests on the two ears of that Bilstein body? The problem I see at that point though is that it would be a lot of pressure on those two ears and the ears eventually shearing off. Perhaps welding on a female receptacle on our stock strut body for it to mount?
Grog6 likes this.
CDsDontBurn is offline
post #37 of 43 (permalink) Old 04-27-2019, 05:15 PM
"Mr. Bilstien, Mr Bilstien! Demand for 3000GT inserts has suddenly doubled! 11-1/2 people are interested!"
Woodman likes this.
post #38 of 43 (permalink) Old 04-27-2019, 05:33 PM
You mean 3; me, MM, and CD's.
And that's guessing about MM, lol. He may already be done with that part, I can't remember.
The Really Nice thing about the tops he made us is that they will fit the Race Konis, but they're only slightly cheaper than Bill's QA's.
And I saw the post about them getting trashed in a single Lemons race.
$350 a race seems steep, somehow, lol.
Maybe they're only $250 to rebuild; but that rebuild price I saw was 10 years ago.
Koni told DLF that there was a powdered metal piece they were out of, and if a rebuild needed that part, they couldn't be rebuilt.
Grog6 is online now
post #39 of 43 (permalink) Old 04-27-2019, 05:42 PM
I’m the half, I’m only interested in spending half what they cost
With that kind of longevity we should just find some Chinese supplier to make them for pennies. I truly don’t give a damn anymore what name is on it.
Grog6 likes this.
post #40 of 43 (permalink) Old 04-27-2019, 07:32 PM
I'm pretty sure that MM is re-using his existing set on his build.
This is the one thing I've been reading about Koni products all throughout. They don't last very long.
My problem is if I'm going to be spending some coin on a product, I'd expect it to last a long time before it needs to be replaced.
You know, I don't mind if it's made in China. There are tons of products that come from China that are built with very high quality. If a high quality product with the features I want comes from China that will work on our car, I'll gladly put it on my car.
post #41 of 43 (permalink) Old 04-27-2019, 08:16 PM
This thread went a long way away from the spring perches question.
If you want to do any kind of performance stuff with this car it does seem apparent that we are into custom territory now. I've said it in the other thread but creating something to act as the carrier for this wouldn't be that hard. The challenge would be finding the appropriate inserts. Koni does offer some of the best models for this but if they are a problem due to reliability then we should think about it a different way.
In any event, I think that if you don't want to race your car then you are probably just stuck with whatever is available from the likes of Amazon, Rock Auto, etc.
Grog6 and CDsDontBurn like this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #42 of 43 (permalink) Old 04-28-2019, 02:43 PM
Agreed; the Gabriel shocks I ran in the early '00's were fine for daily driving, and tended to last about 3 years or so.
They were cheap.
A quick look at Autozone says the Ultra's are $53.
Grog6 is online now
post #43 of 43 (permalink) Old 05-03-2019, 02:05 PM Thread Starter
Zep5.0's Avatar
Just to bring this thread back - I did order and receive the alum "pucks". Ordered form https://www.mcmaster.com/1610t19 - with shipping I have about $25 in them, so just a couple bolts, washer, lock washer, etc. should be good to mount springs. I also ordered a set of prothane spring perches, and there will be about 1/4" of wiggle -but that is not enough to concern me. Thanks for the help gents - I'll bring the shock questions to the other threads once I find some movement there. After looking at the car more in depth, I've got some rot that need attention before these parts are going on the car, unfortunately. Thought it was just the rockers, but goes a little deeper. Anyone have any patience for sale
CDsDontBurn likes this.
Zep5.0 is offline
Similar Threads
Mark VIII LCA Spring Perches Thomas A Parts For Sale 64 09-30-2009 02:45 PM
Spring Perches for Mark VIII LCA's Thomas A Parts For Sale 10 10-27-2007 04:27 PM
Spring Perches for Mark VIII LCA's Thomas A Parts For Sale 5 06-23-2007 11:18 AM
LCA spring Perches Question area slayer Suspension 0 04-16-2004 10:30 AM
