MK VIII LCA spring perches - TCCoA Forums
 20Likes
post #1 of 43 (permalink) Old 04-22-2019, 01:38 PM Thread Starter
Zep5.0's Avatar
Does anyone still make these other than those purchase through SCP? $190 seems a bit spendy for a couple chunks of Alum.. Looked like someone was making them in Delrin a couple years ago, but the posts had dried up since then.
Zep5.0 is offline
post #2 of 43 (permalink) Old 04-22-2019, 02:32 PM
MaddMartigan's Avatar
I just used aluminum bar/cylinder stock. About 1" tall by about 3" in diameter. Ebay. Cheap. I did have to drill holes through them and buy the bolts to hold them in place.
CDsDontBurn likes this.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #3 of 43 (permalink) Old 04-22-2019, 04:00 PM
I used nothing at all
post #4 of 43 (permalink) Old 04-22-2019, 08:16 PM
I used a perch torched out of a set of 89 stamped steel control arms.
post #5 of 43 (permalink) Old 04-22-2019, 08:16 PM Thread Starter
Zep5.0's Avatar
Seems like that would be just as good as the perches and not that tough to do. Thanks for the tip 👍
MaddMartigan and CDsDontBurn like this.
Zep5.0 is offline
post #6 of 43 (permalink) Old 04-22-2019, 10:09 PM
CDsDontBurn's Avatar
Dumb question here guys:
What's the difference between spring perches and spring isolators? Or is it the same thing with an interchangeable term?
CDsDontBurn is offline
post #7 of 43 (permalink) Old 04-22-2019, 10:33 PM
Irv
Irv's Avatar
The white UHMW inverted mushroom cap is the perch. The black poly ring is the isolator. The underside of the perch has a nub that fits in the hole at the bottom of the Mark VIII LCA.
Irv
1997 Ford Thunderbird LX
Irv is offline
post #8 of 43 (permalink) Old 04-23-2019, 01:05 AM
$8 each, thread for a bolt.
Use a steel bolt. Aluminum is too soft, lol.
https://www.mcmaster.com/1610t19
post #9 of 43 (permalink) Old 04-23-2019, 01:59 PM
Woodman's Avatar
They pretty much just center the spring, right? Not really needed as the spring is never loose enough to walk around inside the control arm?
Woodman is offline
post #10 of 43 (permalink) Old 04-23-2019, 02:28 PM
I wasn't comfortable with that, I used aluminum pucks.
post #11 of 43 (permalink) Old 04-23-2019, 11:08 PM
Attachment 34165
Attachment 34167
So based on this new info, I only have isolators and no perches. So I'll need to get isolators as well then?
So this will work just fine then? I'd imagine they'd have to be drilled / tapped to have a bolt fit?
Are there any perches available that are "ready to go" that don't cost an arm and a leg? UHMW mentioned by Irv?
post #12 of 43 (permalink) Old 04-23-2019, 11:26 PM
They were expensive enough I did aluminum, lol. >$100.
I also tried an aluminum bolt, and that was hilarious.
The spring mashed ot off like toothpaste, as I jacked up the arm. I have one left, it weighs about 10grams, vs 30 for steel.
Luckily, I ordered steel at the same time.
I bought the bolts, tap, and pucks for ~$30 total.
Hey, did you ever hear back from Bilstein?
post #13 of 43 (permalink) Old 04-24-2019, 12:13 AM
Hmmm.....looks like I need to add perches to my suspension build.
And no, I've not heard back from Bilstein. I'd settle for Tokicos at this point in time. At the same time though, I've been waiting for MadMartigan to finish his [awesome] build so we can start chatting on potential solutions alternative to Bilstein.
post #14 of 43 (permalink) Old 04-24-2019, 12:59 AM
Yes, without perches the springs naturally sit in the outer edges of the cups rather than dead center in them. It’s not a functional issue however, and they cannot move even at full droop with the suspension assembled. Perches IMO are a waste of money and just make installing springs over them more difficult. Urethane Cobra isolators fully compensate the ride height, which is really the only purpose custom perches truly served.
Woodman and Air2Mud like this.
post #15 of 43 (permalink) Old 04-24-2019, 02:43 AM
Matt is right; there's no way these can come out.
I was worried about them shifting under heavy cornering, so I went as cheap as possible.
Kinda a "belt and suspenders" thing, lol.
It still blows my mind that the lower shock bolt takes all the stress from a 'General Lee' moment.
I've had a few of those in Lazarus.
Woodman likes this.
post #16 of 43 (permalink) Old 04-24-2019, 09:23 AM Thread Starter
Zep5.0's Avatar
This was my next question for my build...I really don't want to put Monroe Sensacrap on a nice suspension setup. Are there really no other solutions? I see you can get KYB, but sounds like they are junk. I thought they used to be a reputable company with good products. Sounds like they are worse than stock replacements. And with lowering the car 1.5", I'd think something more in line with that usable travel, would be better anyway.
Are there any other applications that are similar enough, such as Cobra rears, for instance? I see Bill over at SCP has coil over set-ups, but them you have to buy springs to suit. Can't say i feel the need to spend over $1500 for a spring/shock set-up on a mostly Street car.
Zep5.0 is offline
post #17 of 43 (permalink) Old 04-24-2019, 04:34 PM
wildturkey's Avatar
I saw some Tokico's for 99 Cobra Mustang listed on Ebay for $118 a pair. There are also Koni adjustable.
Read ya later, Nick
wildturkey is offline
post #18 of 43 (permalink) Old 04-24-2019, 04:43 PM
Read this thread:
https://forums.tccoa.com/44-suspensi...nsert-diy.html
And this one:
https://forums.tccoa.com/44-suspensi...ers-front.html
The last problem we have is finding another insert, as Bilstein has likely discoed the insert for the Mitsu3k.
I've been looking.
Read ya later, Nick
Only specific shocks for certain mustangs will work for the Rear only.
Mustangs have struts in the front, and they're not inserts like our koni's were.
I think I bought the last set of konis WBW; DLF and I tried to buy another set, but they were gone.
At the time, they told us we'd need 50 people to buy sets to get them made again.
post #19 of 43 (permalink) Old 04-24-2019, 06:40 PM
KYB will work. I'd put them somewhere between Monroe / Gabriel and Tokico Blues. For what I want to do, the KYBs are not what I want. If KYB had their AGX series available for our cars, I'd jump on those.
That's why I'm not getting his coil-over setup. Just the front two alone is more than half of what I've already spent for suspension already!
There's at least two guys on the FB TCCoA page that are interested in something better than stock replacements. Not sure if they're in this thread posting or not. You and I @Grog6 , make two more. We just need 46 more!
Grog6 and Zep5.0 like this.
post #20 of 43 (permalink) Old 04-24-2019, 09:27 PM Thread Starter
Zep5.0's Avatar
Read through those threads. Basically scared of doing anything like that. Just about 💯 I'll screw something up, if inserts can even be found.
Zep5.0 is offline
post #21 of 43 (permalink) Old 04-24-2019, 10:20 PM
Dude; it's not that hard.
Remove the guts by cutting, hacksaw or dremel tool.
Bolt in insert, add springs, you're done.
It took like 2 hours to do.
What is special is that the ones that fit are disco, the Tbird ones, and the diameter of the shaft is different requiring alterations to the existing top insulator, as shown.
MM made me a set, and if I want to go to the ultra expensive Koni double adjustable shocks, they'll fit.
This is Not rocket science, I do that, and IT's hard.
I had a chance to take Lazarus and the Tbird up the mountain yesterday, and the konis are Way better than the tokicos; even after all they've been thru.
The konis track this one section, where the tokicos just bounce. I'm glad I did the konis first there; I'd have been to scared to hit it like that after the tbird run, lol.
Eating a rock wall is not my idea of fun.
CDsDontBurn and Zep5.0 like this.
post #22 of 43 (permalink) Old 04-25-2019, 11:13 AM
Definitely not hard to do. The only thing I know I'll need will be the "top hat" to be made by MM. If I had a spring compressor I'd install it all myself.
post #23 of 43 (permalink) Old 04-26-2019, 09:22 AM Thread Starter
Zep5.0's Avatar
So it seems the Bilsteins are still available. Any reason NOT to just buy these and do this? https://www.amazon.com/Bilstein-34-0.../dp/B009FU5ZBU
Zep5.0 is offline
post #24 of 43 (permalink) Old 04-26-2019, 09:52 AM
“Usually ships within 1 to 3 months.”
Ask cdsdontburn how many months he’s waited.
post #25 of 43 (permalink) Old 04-26-2019, 10:21 AM Thread Starter
Zep5.0's Avatar
Dang - didn't see Months, saw it as days, since that is usually what I see there...the search continues. Was hoping i had good news for everyone!
Zep5.0 is offline
post #26 of 43 (permalink) Old 04-26-2019, 05:54 PM
Here, I'll just show everyone how long I've been waiting.
post #27 of 43 (permalink) Old 04-26-2019, 09:51 PM Thread Starter
Zep5.0's Avatar
My lawyer wouldn't approve of this but...I hope I have some good news. I contacted a truck spring/shock shop of all places after finding they sold them online. Received an email back... Here it is.
Seth,
We currently do not have the 34-050224 in stock. I checked with Bilstein and
these are on backorder until mid-late June. Please let me know if you have
any questions or if I can be of any assistance.
Thank you,
Dave Anderson
Michigan Truck Spring
www.TruckSpring.com
1-800-358-4751
989-755-0561
Now, thinking I want to buy from them since they made the call for me, but wondering if I ordered from say Summit, would that ensure delivery, or make it more probable? Thoughts?
Zep5.0 is offline
post #28 of 43 (permalink) Old 04-27-2019, 12:54 AM
No one will have these until Bilstein makes more; it may not happen at all, based on my experiences with Koni.
It's not like they give a fuck about us, lol.
post #29 of 43 (permalink) Old 04-27-2019, 09:50 AM
Woodman's Avatar
It's always a numbers thing. The cost to setup the tooling to make that type of insert has to have enough demand to make it worth the time/effort. If they can't make money off it, no sense doing it.
Woodman is offline
post #30 of 43 (permalink) Old 04-27-2019, 10:58 AM Thread Starter
Zep5.0's Avatar
Lol, true true. But if you could all go order a set, that'd be great, lol.
Zep5.0 is offline
Similar Threads
Mark VIII LCA Spring Perches Thomas A Parts For Sale 64 09-30-2009 02:45 PM
Spring Perches for Mark VIII LCA's Thomas A Parts For Sale 10 10-27-2007 04:27 PM
Spring Perches for Mark VIII LCA's Thomas A Parts For Sale 5 06-23-2007 11:18 AM
LCA spring Perches Question area slayer Suspension 0 04-16-2004 10:30 AM
