Suspension Knock - TCCoA Forums
 3Likes
  • 1 Post By Trunk Monkey
  • 1 Post By Rodeo Joe
  • 1 Post By T6Rocket
post #1 of 12 (permalink) Old 05-07-2019, 01:39 PM Thread Starter
Suspension Knock
There is an odd knock from the drivers side front when the suspension compresses. It's very random, but will happen every time I go over a speed bump. I was under there with a pry bar and everything is tight, both with wheels on the ground and supported by the frame with on weight on the wheels. It's kind of driving me crazy, any thoughts on what to check out? The smurf is lowered 1.5" with eibachs on Tokico shocks. UCA & LCA are newer MOOG, strut rod bushings are new, factory rubber to sub frame.
Kidd-7 is offline
post #2 of 12 (permalink) Old 05-07-2019, 03:29 PM
Probably the sway bar end link.
CDsDontBurn likes this.
post #3 of 12 (permalink) Old 05-07-2019, 03:47 PM
^^^ My first thought as well.
97 Laser Red Thunderbird LX 160k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
98 Black Mark VIII 151k, stock daily driver
07 Redfire Fusion V6 SEL 176k, for the wife
post #4 of 12 (permalink) Old 05-07-2019, 09:54 PM
End link or bushing.
Fuelly
RalphP is online now
post #5 of 12 (permalink) Old 05-08-2019, 05:15 AM
X4!
Trunk Monkey likes this.
post #6 of 12 (permalink) Old 05-08-2019, 08:49 AM
T6Rocket's Avatar
Sway bar end link. X5!
This applies to rattles from the rear also.
Al
97 T-Bird LX 4.6 - 78k miles
04 CVPI- Brenda's car - 71k miles
Previous Fords:
T6Rocket is offline
post #7 of 12 (permalink) Old 05-08-2019, 12:45 PM
CDsDontBurn's Avatar
Sway bar end link.....X6!!
CDsDontBurn is offline
post #8 of 12 (permalink) Old 05-13-2019, 09:27 AM Thread Starter
I got under her this weekend and those links feel tight. I used a pry bar and rubber mallet to try and get some movement I'd expect to see from a worn out ball joint and nothing. I expect you're going to say replace them anyway. I used MOOG last time, but I don't like how the boots float on the ball joint. Rockauto has Moog & Proforged in the premium section and AC Delco, Motorcraft and Mevotech in the daily driver. All are in similar price range. Moog & Mevotech are shaped similar while the other have a straight bar. Looks like Moog, Delco & Mevotech are greasable, with Delco & Mevotech having a ring on the boot to hold it in place. Now the question, what do ya'll recommend?
Kidd-7 is offline
post #9 of 12 (permalink) Old 05-13-2019, 02:32 PM
There's so much force on those while the car is jacked up, you can't move them.
If you take the two endlinks loose at one end, you will find that one end is frozen, and the other end rattles easily.
Especially if they do not have grease fittings.
These are the best ones I've found, by ACDelco, which is the ones Raybestos Professional used to make. ACD bought Raybestos 10 years ago or so.
Grog6 is online now
post #10 of 12 (permalink) Old 05-13-2019, 02:55 PM
T6Rocket's Avatar
I will add to not over tighten the nuts. I stripped one once, and replacing it next time required a die grinder.
Al
Grog6 likes this.
Previous Fords:
T6Rocket is offline
post #11 of 12 (permalink) Old 05-13-2019, 03:22 PM
Al
Agreed; I've also had issues with the bolt that goes thru the spindle rusting in place; if you mushroom it with a hammer, you'll be using a die grinder and a punch to get it out.
The links I posted above have 'deformed' features; you can see the three indents in the top of the bolt.
They will not loosen on their own.
They Can be a bitch to get to tighten; seems like the ones I bought had a hex in the end to aid in tightening/removal, but I'm not sure, it's been years since I replaced those.
An impact works, either way.
The greaseable ones last much longer than the regular ones.
Grog6 is online now
post #12 of 12 (permalink) Old 05-15-2019, 05:52 PM
gordonm1's Avatar
It sounds like the end links are the culprit but the first time I bought front shocks, I did not want to pay for new mounts at the top of the shock. I got a "schrunch" going over every speed bump with the new shocks.
gordonm1 is offline
Similar Threads
knock knock! Jestkdn Engine - 4.6L & 5.4L 4 10-19-2006 03:43 PM
Knock, Knock... Juice Engine - 3.8L & 4.2L 9 02-09-2006 11:31 PM
Knock, knock.... Tony Engine - 4.6L & 5.4L 5 01-02-2006 01:56 PM
Knock Knock quadcells Engine - 3.8L & 4.2L 29 08-03-2004 04:03 PM
Knock Knock Knock rbrown Engine - 4.6L & 5.4L 7 09-08-2002 12:04 PM
