Rear subframe part identification - TCCoA Forums
post #1 of 7 (permalink) Old 05-11-2019, 06:05 AM Thread Starter
Hello all.
Help needed to identify the correct part.
Unfortunately I have not yet found any diagram which would illustrate this part.
The part seems to hold the rear subframe in place. Part is bolted just under the chassis and rear wheel arch. Some kind of big about palm size bushing between this needed part and subframe.
Tried to explain as good as I can
Need a new part for mot inspection and get my Tbird road legal again.
Thank you all.
Cheers from Finland.
Ford T-bird 1992 V6 daily runner
Ford Capri Cologne V6 2.9 EFI turbo summer ride
Kawasaki ZX14 2008
hessu75 is offline
post #2 of 7 (permalink) Old 05-11-2019, 06:48 AM
I have some bad news; those bushings are long out of production.
The only replacement parts are either Delrin or Aluminum.
Check out this thread:
https://forums.tccoa.com/20-parts-sa...ble-again.html
Jay hasn't been around lately, but Bill at SCP has some as well.
Here's a set in stock:
https://www.supercoupeperformance.co...6-aluminum-852
Sorry to hear you're having problems, but this is a pretty common problem at this point.
The good news is that the Knuckle and LCA bushings are available in poly.
post #3 of 7 (permalink) Old 05-11-2019, 12:24 PM
The steel stabilizer brackets are still available from Ford as far as I know, I assume that’s what you’re describing. If it’s the bushings and top cups you need grog is correct that they are no longer available.
E9SZ 5D022 A and E9SZ 5D022 B are the part numbers for the stabilizer brackets
The bad news is the subframe bolts in the center will probably break when you try removing them, as I can assume rust is why you need these brackets. The bolts will have likely seized inside the bushing sleeves.
post #4 of 7 (permalink) Old 05-11-2019, 05:04 PM
I completely misread the OG post, sorry.
I could not bring myself to 'like' those pix; damn, I'm lucky to live where I do.
I bet the OP sees even more snow than you do, Matt!
post #5 of 7 (permalink) Old 05-11-2019, 06:41 PM
Matt,
Are they the same for front and rear?
post #6 of 7 (permalink) Old 05-11-2019, 08:05 PM
Originally Posted by Rodeo Joe View Post
Matt,
No, the rear stabilizer brackets are simple round cups, they don’t bolt to the frame rails like the fronts do.
If you’re talking about the top cups also in the pics I posted, those are different parts, and obsolete, but they are the same all around.
post #7 of 7 (permalink) Old 05-11-2019, 09:04 PM
OK, brain cramp, thanks!
Similar Threads
Noob part identification test RichardM Newbie Forum 9 10-04-2015 08:56 PM
WTB Rear LCA toe bolts and rear subframe bolts/nuts sleepyhead Wanted 4 12-28-2012 10:08 AM
Part identification spctrbytz Exterior 2 02-11-2009 08:18 AM
Part Identification Help DMcBrideBoston Interior 9 12-01-2005 10:40 PM
Rear Valence Identification FordMan77 Exterior 7 11-28-2005 12:34 PM
