Front Lower Control Arms Material - TCCoA Forums
 3Likes
  • 1 Post By Grog6
  • 2 Post By MaddMartigan
post #1 of 5 (permalink) Old 07-29-2019, 12:03 PM Thread Starter
MaddMartigan's Avatar
What material are the front lower control arms made from? Cast iron or forged steel?
I'm asking because I'm thinking about an off season project to make adjustable front LCAs by modifying the stock part.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #2 of 5 (permalink) Old 07-29-2019, 12:42 PM
I've sawed one in half, it's steel; IDK forged or not.
It is definitely NOT cast iron.
It wasted a sawzall blade; I was making a brace for a project out of one of the ones with non replaceable ball joints, and it was just the right size.
Two of them take full up sledgehammer blows; so it's some tough stuff.
MaddMartigan likes this.
Grog6 is online now
post #3 of 5 (permalink) Old 07-29-2019, 12:59 PM Thread Starter
Excellent. So that means that it will be weldable much easier than cast iron is. Now I just need to find some old ones to experiment with before I go whole hog.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #4 of 5 (permalink) Old 07-29-2019, 01:01 PM
I'll look later today; If I didn't recycle them, I have a set.
I'll give them to you for shipping.
They would be stock TRW from the bird. If I kept them.
I do tend to keep crap like this, just in case I run over another curb, lol.
Grog6 is online now
post #5 of 5 (permalink) Old 07-29-2019, 01:15 PM Thread Starter
The more I'm thinking about it the more I'm wondering if I wouldn't just make everything from the strut rod with turnbuckles and a new LCA designed around that particular design.
Of course, I'm just fantasizing at that point.
Grog6 and CDsDontBurn like this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
Similar Threads
TRW Front Lower Control Arms Rayo Miscellaneous 2 07-26-2016 09:22 PM
Front Upper & Lower Control Arms mike884_2 Wanted 0 03-03-2010 08:38 AM
lower control arms...need a special tool? The Great Obucina Tires/Wheels 6 06-14-2003 09:25 PM
Lower control arm polyurethane bushing problem - won't press into control arms Kleckner Tires/Wheels 0 03-21-2003 03:01 PM
