Hub/Bearing - TCCoA Forums
post #1 of 10 (permalink) Old 01-13-2004, 08:16 AM Thread Starter
Hub/Bearing
I just bought some 92 SC front hubs. I got them cuz as i understand it they will allow me to run a 9 inch wide rim up front with 45s on them. Only problem is the bearings are going. Now i know these are sealed units but i know there is a way to replace the bearinbg with a press but is there any other way?
Highland Thunder is offline
post #2 of 10 (permalink) Old 01-13-2004, 04:14 PM
jk69cat's Avatar
i hate to break it to you , but they are not different. they are the same part number.
mn12 less!
jk69cat is offline
post #3 of 10 (permalink) Old 01-13-2004, 05:30 PM Thread Starter
Well your the first person to tell me that. They are diffrent. thats why u can run wider rims on older MN-12s
post #4 of 10 (permalink) Old 01-13-2004, 06:20 PM
Cougar Pilot
BlackCat94's Avatar
I think it's because of the spindle
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #5 of 10 (permalink) Old 01-13-2004, 06:25 PM Thread Starter
Well is the spindel not aprt of a mn12s hub?
post #6 of 10 (permalink) Old 01-13-2004, 07:36 PM
Rolling-Thunder's Avatar
The hub/bearing assembly is separate from the spindle.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #7 of 10 (permalink) Old 01-14-2004, 07:38 AM
jk69cat's Avatar
ok been thru this before, the hubs are the same. they list different numbers for 89-90 , but the the 91-97 hubs are all the same number. and actually you can use the 91-97 hub on the 89-90 car, the spindles are the same from 1989 to 1992 , 93 up use the mark spindles. the bearing is not repalceable seperate either you have to buy a new hub.
mn12 less!
jk69cat is offline
post #8 of 10 (permalink) Old 01-14-2004, 09:51 PM Thread Starter
So i go boned? Well thats lovely
post #9 of 10 (permalink) Old 01-15-2004, 07:54 AM
jk69cat's Avatar
unfoutunatly that sounds like what happened.
mn12 less!
jk69cat is offline
post #10 of 10 (permalink) Old 02-12-2004, 04:58 AM
I've actually heard a couple different stories about the bearings. Some people say you can remove and replace, some say no. You certainly can't buy the bearings separately from Ford. I don't know how to do it either way, but I have heard it's possible.
Steve
S_Mazza is offline
