Best suspension for 100mph+ - TCCoA Forums
post #1 of 9 (permalink) Old 01-20-2004, 05:11 PM Thread Starter
Send a message via AIM to chrisnack
Curious as to thoughts from others on how to beef up the suspension to handle my autocross and other track events.
I'm gonna try and get all the KB braces on before the season starts, I'm more concerned with my suspension this year than the engine.
I have a race in June where I'll be hitting 100mph+ many times, so curious as to what you guys think should be beefed up?
If all goes well, I'll have my 17x9 Cobra R's. STB, RTLB, hopefully the 1-1/4 or 1-3/8 front and rear bars. And then I was thinking about the other front braces as well.
My harness and racing should be in there possibly by then as well, we'll see. Harness for sure, I slid around too much last year. But not sure on the seat yet. That will kill my "stock" look.
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #2 of 9 (permalink) Old 01-20-2004, 05:19 PM
Sweet T
SanDiegoLXBird's Avatar
I'd be more concerned with the drive train at 100+ mph. At the very least, upgrading to poly bushings and a solid tranny mount to keep drive train movement at a minimum. Getting a Mark VIII ds would probably also be a good temporary safety measure, unless you've got a MMX DS in the works already.
I'm nothing even close to resembling an expert, but at the times I have hit 100+ in my car, I was more worried about the extreme vibration that I experienced than the suspension. The stock LX suspension seems okay at those speeds in a straight line, but I'm not too sure about maneuverability. The standard stuff should be okay, something low to the ground with a good, stiff chassis, shocks and springs and you'll be fine. BUt like I said.. I'd be more worried about the drive train.
1994 SC 5-Speed
SanDiegoLXBird is offline
post #3 of 9 (permalink) Old 01-20-2004, 05:45 PM Thread Starter
I don't have any problems at 100 or so. No vibration. Smooth as if i was doing 80.
NSN Motorsports
'96 Eagle Talon ESI
post #4 of 9 (permalink) Old 01-20-2004, 08:46 PM
96bird's Avatar
Chassis braces are a good place to start. A good foundation is essential to a car's predictability at high speeds. I would look into upgrading the driveshaft as a safety measure. It sounds like you should be alright with the other mods that you posted.
Russell
96bird is offline
post #5 of 9 (permalink) Old 01-20-2004, 10:36 PM
fast Ed's Avatar
I'd suggest getting a set of Koni or Bilstein shocks under there as well, if you plan on doing those type of events on a regular basis. And also the best tires you can afford to put on those new wheels.
I have Konis in my car now (had the SC electronic replacement Tokico Illumina 2s before, they went soft pretty quickly) ... car works pretty well at the open-track events I've been at the last few years, well over 100 mph at Mosport and Watkins Glen. Mine also has the stock front SC stab. bar, early style SC rear bar, Eibach springs.
cheers
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #6 of 9 (permalink) Old 01-20-2004, 10:53 PM Thread Starter
Oh, you don't ever have to worry about me on that one. I run strickly summer tires in the summer. Snows in the winter.
I'm looking at well over $500 for my new set of summer tires. I'm looking at getting a set of Eagle F1's, or maybe Potenzas, haven't decided yet. But either way, close to $180/tire.
From my experience, there is a MASSIVE difference in the quality of tires, and the especially the performance of the tires. Besides, it's your ONLY contact with the road, all the power in the world does you no good if you can't hook up.
NSN Motorsports
'96 Eagle Talon ESI
post #7 of 9 (permalink) Old 01-21-2004, 11:37 AM
fast Ed's Avatar
The latest version of the GY Eagle F1 tires are awesome performers ... you can't go wrong with those. I have the previous generation Goodyears on my street wheels, 255-45-18 Eagle F1 GS D2 ... they are made in Germany, I think the new D3 version is as well. The Bridgestone S-03 tires are nice too, I don't think they have quite as much dry grip as the Goodyears. On the track, I run some used Hoosier Grand-Am Cup 275-40-17 DOT race radials, on 03 Cobra wheels.
As you get into it more, you may want to consider looking at the Cobra brake upgrade as well. I had the Mark VIII / 4.6 Sport pkg. 11.6" brakes on mine for a few years, they weren't bad on the track. But with the 13" rotors, the braking is fantastic now. I did 7 track days this summer, and the rotors are still perfect. Two sets of front pads killed though !! The drawback of course is that you need to switch back for the winter, or get a set of 17" winter wheels and tires. I didn't do the 13s on mine until it became a summer-only car.
Good luck, have fun this summer !!
cheers
Ed N.
fast Ed is offline
post #8 of 9 (permalink) Old 01-28-2004, 10:01 PM
What kind of harness setup are you going with? I'd want a 5 or 6 point harness, and you'll need a roll bar behind your seats to mount those properly.
mercutio is offline
post #9 of 9 (permalink) Old 01-31-2004, 06:50 PM
Get the alignment changed too. Most high speed cars have more caster for stability. Firm suspension is a must.
Read up on it is my best suggestion.
The way my car is now it is like butter at 100+ but it hugs the road so you don't get that feeling of float at all.
RichardM is offline
