cutting 1 coil off front sport springs - TCCoA Forums
post #1 of 13 (permalink) Old 02-04-2004, 12:54 PM Thread Starter
ThunderB's Avatar
Is it possible to cut a single coil off of the front springs without taking the shock/spring off the car? I like ride of my '97 sport, but it sits front high and I'd like to drop it 3/4 to 1 inch to even it out. Anyone done it?
B
97 T-Bird Sport: Dynomax catback, Removed silencer w/ K&N panel, DReinhart chip, Lightning AGSF12-FM1 plugs/180 stat, Tokico 1.25" dropped stance, bye bye fender gap
'79 F100 SB : 300 ci six, Hurst Mastershift 3spd floor shifter, Offenhauser intake, Holley 4 brrl, EFI manifolds, Chebbie Rockers, Summit Racing 3.50 gearset, DISO 2.5" diesel muffler and 2.5" exhaust, Its'a six?!
ThunderB is offline
post #2 of 13 (permalink) Old 02-04-2004, 07:43 PM
JoeyICU's Avatar
the birds are suposed to be rear high....if your fronts higher then your rear you may have bad rear springs....and id guess you have to take the strut off to cut the coil off in the front....unless you heat the springs....witch is very bad....b/c you lose sitffness
JoeyICU is offline
post #3 of 13 (permalink) Old 02-05-2004, 07:41 AM Thread Starter
ThunderB's Avatar
All the stock birds I have seen seem to sit front high, sport or no sport. i would do Eibachs, but they do the same thing, only lower. I have over 100k, so it may be time to start looking at some replacement suspension (shocks/springs)anyway, but my car rides and handles great. I'm with you on heating the springs, i have always heard it is a bad idea. i don't want to add the extra cost and complexity of airbags if I go with Eibachs later, just to even the rear.
B
ThunderB is offline
post #4 of 13 (permalink) Old 02-05-2004, 08:22 AM
JoeyICU's Avatar
maybe im crazy but theyve always looked a little rear high or level....im not 100% sure tho...my buddys lowered bird sits level
JoeyICU is offline
post #5 of 13 (permalink) Old 02-05-2004, 09:07 AM
Jedi Master
mn12xr7's Avatar
my old cat sat higher in the rear, the present cat sits fairly even
-Orlando
mn12xr7 is offline
post #6 of 13 (permalink) Old 02-05-2004, 09:54 AM Thread Starter
ThunderB's Avatar
Hmmm, maybe the rear springs have sagged a bit then. would still be nice to even the front with the rear by cutting a coil. the front isn't an inch higher than the rear or anything , it just appears to have more fender gap, and that is what I want to reduce for a more balanced look. if I have to take the spring soff to cut them, I might as well replace them. That is why I am hoping t cut off a coil without removing them. Maybe I can get my hands on some spring compressors and see If i can mount them while the shock/spring is still on the car.
B
ThunderB is offline
post #7 of 13 (permalink) Old 02-05-2004, 12:16 PM
MaleWhore
smokymance's Avatar
all 3 birds i have had sit higher on the back...especially my 97 sport....
smokymance is offline
post #8 of 13 (permalink) Old 02-05-2004, 04:58 PM
Lightbulb
I would not cut it well it is no the car or the strut because it is under compression u start cutting it and it is going to snap. As for the car "sitting high" the wheel wells are diffrent sizes the front is bigger. If you want to lower ur car bu cutting ur springs i did it. I took off 2 coils and it lowered it 1.5". i ended up lowering my can 3" in front and in the rear i dont remember just so the tire was at the wheel well.
if u want to cut springs do it with the spring off the strut and to take the spring off the strut use spring compressors or it will shoot off.
frkyeye is offline
post #9 of 13 (permalink) Old 02-05-2004, 06:35 PM
Silver95Bird's Avatar
My car sits 3/8" higher in the rear than in the front. Yes, I measured.
Silver95Bird is offline
post #10 of 13 (permalink) Old 02-05-2004, 06:52 PM
JoeyICU's Avatar
its suposed to be like 13"s from the pinch welds to the ground in the frony...n like.....14 or 15" in the rear.......dont quote me on that i forgot......if it matters i can look it up 2morow....or....if i alighn my car....ill look it up when i do that
JoeyICU is offline
post #11 of 13 (permalink) Old 02-09-2004, 01:29 PM
DO NOT cut a coil with the spring still in the car, it's dangerous, and frankly, it's stupid. My car with sport springs sits high all the way around, but higher in the back. Take the springs out, cut them, and then put them back in, doing 1 at a time, and take off a little at a time, until you are happy with the ride height. It takes some time and work, but you'll be happier with the finished product.
Rich95XR7 is offline
post #12 of 13 (permalink) Old 02-09-2004, 01:48 PM
i hit a big bump after cutting the springs and the upper control arm bustted a hole thru the unibody structure so be careful on how much
frkyeye is offline
post #13 of 13 (permalink) Old 02-11-2004, 09:43 AM Thread Starter
ThunderB's Avatar
Alright, really bad idea to cut springs while still on the car. I'll look and see how difficult it is to pull off the shock to and have a shop remove the spring so I or they can cut off a coil.
I measured my car an it is a 3/8 inch lower in back than front. Sounds like my rear is already lowerd , all I have to do is drop the front a tad.
thanks for the responses
FRKYEYE, how much spring did you cut? sound like your suspension bottomed out big time. What were you doing, catching some air?
B
ThunderB is offline
