Removing front sway bar - TCCoA Forums
post #1 of 3 (permalink) Old 02-10-2004, 01:01 PM Thread Starter
Roy Batty's Avatar
Ok. I am trying to intall my sway bat, and cannot seem to get the stock off. The problem is in the sway bar end links. How do I get them off the car? I tried hitting them with a hammer, with no forward progress. Help would be appreciated.
Everyday of my life is a constant fight, between wrong and right.
When there is no grass on the field, go around back and play in the mud.
Roy Batty is offline
post #2 of 3 (permalink) Old 02-10-2004, 01:16 PM
Mark M. TCCoA VP's Avatar
What do you mean? The front sway bar just unhooks and drops right out in like 2 min....LOLLOLOLOLOL
Seriously, check out the tech section of this site for bar related articles.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #3 of 3 (permalink) Old 02-10-2004, 05:57 PM
I just replaced my endlinks. What you need is a ball joint seperator/removal tool. You can get a loaner from Autozone.
It looks like a tuning fork. You slip it between the sway bar and the endlinks and then pound the %^%& out of it and pry the links from the sway bar.
That is the hardest part of the job.
gzj14v is offline
