Replaced upper control arm - TCCoA Forums
post #1 of 3 (permalink) Old 03-01-2004, 07:33 PM Thread Starter
Rolling-Thunder's Avatar
Finally had an upper ball joint wear out at 205,000 miles.
Driver's side had about 1/8" of side to side play in it.
Glad to see the new motorcraft ones have a grease fitting.
Tools needed;
Trolley jack, and one jack stand.
18mm 6 point combination wrench.
18mm Craftsman ratcheting combination wrench.
Torque wrench.
Torch - to heat up the upper spindle arm.
Lots of brute strength....lol
Worst part of job for me. Separating the ball joint stud out of the upper spindle arm.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #2 of 3 (permalink) Old 03-01-2004, 11:41 PM
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
Last weekend I started to disassemble the suspension in anticipation of our GP lowering springs. The rear springs came right out after a few bolts were removed. The right front spring/shock assembly also was cake. The left front we had to wrestle with the upper spindle like you did and the worst part - I cannot get the lower shock bolt out of the lower control arm bushing. The nut is off, it turns, it just won't come out!
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
post #3 of 3 (permalink) Old 03-02-2004, 07:38 AM Thread Starter
I haven't removed a lower shock bolt before, but if you search thru the forums, someone posted the details on getting that out. I think there is a split steel sleeve around the bolt. Corrossion probably 'fuses' the three together (control arm, bolt, sleeve)
