Rear sway bar - TCCoA Forums
post #1 of 2 (permalink) Old 03-07-2004, 10:51 PM Thread Starter
Rear sway bar
Is there a difference in size between my 96 3.8 LX and a 96 sport/V8? Would it be worth it to swap it out if there is a difference?
ornithophobia96 is offline
post #2 of 2 (permalink) Old 03-07-2004, 11:42 PM
96bird's Avatar
The 3.8 has a 1.04in. tubular bar, while the 96 sport has a 1.06in. solid bar. The 1.04in. tubular bar has the same effectiveness as a smaller solid bar. So, yes there will be some difference, but probably not enough to warrant a change. I would suggest the 1 1/8 addco bar or an '89 SC rear bar instead.
Russell
96bird is offline
