Are Endlinks vital to replace when busted? - TCCoA Forums
post #1 of 6 (permalink) Old 03-09-2004, 09:24 AM Thread Starter
KevinM's Avatar
Send a message via AIM to KevinM
My endlinks are busted, I was jsut wondering how vital is it that I replace them. The car is not my daily driver so I don't drive it much, but when I do it is usually on the highway for a coupel hours or more. Am I at risk of seriously breaking something if I leave them be for the time being, ro should I go ahead and replace them.
Kevin M
KevinM is offline
post #3 of 6 (permalink) Old 03-09-2004, 10:26 AM
Swaybar endlinks, right?
You'll experience a lot of body roll, and possible loss of control-not to mention the possibility of breaking other things-at highway speeds. You should replace them.
Birdman93 is offline
post #4 of 6 (permalink) Old 03-09-2004, 11:51 AM
JustinH's Avatar
just remove the front swaybar if you are refering to the front endlinks.
JH
JustinH is offline
post #5 of 6 (permalink) Old 03-09-2004, 04:50 PM Thread Starter
KevinM's Avatar
Sounds like I will be replacing my endlinks now. I have already done the upper control arms, but what about the bushing that is at the bottom of the suspension, the one on my drivers side is slightly busted, can I buy just taht bushing or do I have to buy the entire lower arm. Also my grease fittings don't seem to hold grease very well, should I replace them as well and if so once again, can I buy them by themselves? Where is the best place to buy these parts, and what are the official names for the grease fitting joint and the other lower joint that has no grease fitting on it?
Thanks for your help,
Kevin M
KevinM is offline
post #6 of 6 (permalink) Old 03-10-2004, 08:28 AM
motor city poster
Red96Bird's Avatar
mine arent broken...but the one on the passenger side is shot... ive been told that that could be the problem that is making a few clunking sounds comin out of the front passenger side because the one on the driver side was replaced... would that be my problem?? how hard are they to replace and how much?
Red96Bird is offline
