Endlink and LCA removal question - TCCoA Forums
post #1 of 2 (permalink) Old 03-10-2004, 10:09 PM Thread Starter
KevinM's Avatar
Send a message via AIM to KevinM
I decided to replace my endlinks and LCA's while i had the suspension apart. I cannot seem to get the endlink free from the sway bar or get the LCA free from the spindle. I have the tool that is called I tie rod end separator that i thought was supposed to accomplish this but it isn't working very well. Does anyone have a trick of the trade, or any method that has been used to free the parts form each other. Any input would be greatly appreciated.
Kevin M
KevinM is offline
post #2 of 2 (permalink) Old 03-13-2004, 06:31 PM
i just did that job on my 91 bird upper/lower struts and all bushing/power sterring rack too..i work for a bodyshop.... and i hit the lower spindle with a 5lb hammer just make sure the nut is off or it wont come off (the nut will just spin)it a locking type..it only took 3-5 hits and just pops out..make sure u hit dead on the lower part.. of the spindel not the lower ball joint...it may be harder if the car not on a lift (mying was) but it works.... i did the same to get the outer tie rods out too.....
davids4x4 is offline
