How to tell if Bilsteins have been revalved - TCCoA Forums
post #1 of 1 (permalink) Old 03-11-2004, 10:08 AM Thread Starter
96bird's Avatar
The subject says it all. The front shocks had small notch marks on the inside of the bottom mount. Jack at Bilstein didn't tell me what the revalve was going to be he just said that it would take the bounce out. It did take the bounce out buy I was expecting a little bit more of a firm ride. I think the ride will stiffen up when I get the new tires on because I can feel the large sidewalls of my current tires (225/60/16-not performance tires either) flexing under most bump conditions. Thanks for any help.
Russell
96bird is offline
