Side to Side Clunk - TCCoA Forums
post #1 of 9 (permalink) Old 03-15-2004, 08:18 PM Thread Starter
Side to Side Clunk
I have a clunk in the rear (specifically the drivers side rear). It clunks around turns and I have yet to get under the car and do the proper inspections, but...
When I turn to the right, it'll clunk. If I make another right turn, nothing will happen. But as soon as I make a left, it clunks again. Then if I make another left, nothing will happen, but as soon as I make a right, it clunks. It's a side to side thing.
Any suggestions?
Hill1513 is offline
post #2 of 9 (permalink) Old 03-15-2004, 09:27 PM
I was just about to post about something like this with mine. It will do something like that, but only when I corner hard. If I corner at normal driving speed, it won't do it. I'm thinking possibly a loose RSB?
nidex is offline
post #3 of 9 (permalink) Old 03-15-2004, 09:34 PM Thread Starter
Yeah, mine used to do it only under hard cornering, but now it has gotten worse. It's probably time to check it out.
Hill1513 is offline
post #4 of 9 (permalink) Old 03-17-2004, 06:29 PM Thread Starter
Anybody?
Hill1513 is offline
post #5 of 9 (permalink) Old 03-17-2004, 06:55 PM
Just about to post similar question about my 97. Under hard accelerate in straight line or left turn, I feel bump/thunk on left side in the rear. I'm wondering if a rubber spring mount has worn. I was also leaning toward bushing in control arm or cv joint.
At speed, there is no vibration, shimmying, or any other odd sound.
David
DavidS is offline
post #6 of 9 (permalink) Old 03-17-2004, 07:09 PM Thread Starter
Luckily, I know my problem isn't the CV joint. Everything there looks fine. I was thinking bushing too...but still stumped.
Hill1513 is offline
post #7 of 9 (permalink) Old 03-17-2004, 07:12 PM
Just as long as something doesn't break when I'm running in traffic trying to get home. Out of control at 80 in this traffic could be messy.
DavidS is offline
post #8 of 9 (permalink) Old 03-19-2004, 06:33 PM
I had something similar a few years back, I had 3 broken springs. good excuse to drop it.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #9 of 9 (permalink) Old 03-22-2004, 12:08 PM
I have actually thought it might be spring related. A while back when I replaced the rear springs, I re-used the rubber mounts (or whatever you call them). One of the left rears looked pretty bad.
DavidS is offline
