Where do I order short endlinks? - TCCoA Forums
post #1 of 6 (permalink) Old 03-15-2004, 10:44 PM Thread Starter
I'm getting my Cougar lowered and was wandering if there is a website I can order from or contact. I guess addco makes endlinks, but what part # do I need?
90' Cougar Sport Edition 3.8 (RIP)
92' Cougar 25th Anniversary Edition 5.0
96' Contour Sport (RIP)
01' Jaguar XJR
Stoltz13 is offline
post #2 of 6 (permalink) Old 03-15-2004, 11:27 PM
The Great Obucina's Avatar
Pepboys sells universal Energy Suspension endlinks that will work. I posted the PN for the ones that will fit our application...do a search it will be there
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 6 (permalink) Old 03-16-2004, 05:05 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
stoltz13 did you ever find out the part number for that i need it too. thanks
CamellionCat
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #4 of 6 (permalink) Old 03-16-2004, 10:55 PM Thread Starter
No, but I talked to a person from addco who said it was unnecessary to get shorter endlinks. I also have a friend who is very knowledgeble and he also said it would be uneeded based on the fact the bar pivots in it's mounts on the car's body and thus isn't affected by the ride height. It seems to make sense because otherwise your suspension geometry would change everytime you go over a bump. The bar is designed solely to keep pressure on the wheel on inside of the turn by transfering the twisting force caused by body roll from one side of the car to the other. It isn't suppose to effect the upward or downward motion of the body, just the relationship of the wheel on one side of the car to the wheel on the other side.
So what do you think, do I need shorter endlinks for a 1.5 drop?
01' Jaguar XJR
Stoltz13 is offline
post #5 of 6 (permalink) Old 03-16-2004, 11:58 PM
some ppl say that the shorter endlinks will allow the rear of the car to get lower.
I have over 3 inches of drop and stock endlinks. Ideally you want the bar parell and the control arms to the ground but that does not always happen.
aduty is offline
post #6 of 6 (permalink) Old 04-01-2004, 10:18 AM
jk69cat's Avatar
so i am ok with the stock links on the back of my lowered bird then, i have eibach lowering springs on it and im pretty sure stock sway bar. i will be reinstalling them then this weekend.
mn12 less!
jk69cat is offline
