Poly Shock bushings - TCCoA Forums
post #1 of 4 (permalink) Old 03-26-2004, 10:15 PM Thread Starter
4 Cam Bird's Avatar
Poly Shock bushings
Will the MN-12 performance poly shock bushings fit the lower mount point on Bilsteins?
2011 CTS-V Wagon
4 Cam Bird is offline
post #2 of 4 (permalink) Old 03-27-2004, 02:29 PM Thread Starter
4 Cam Bird's Avatar
Well, the answer is a big NO. Decided to try. But I got the bushing out and was able to get it back in without messing it up. The poly bushings were way to small in diameter and maybe to short too.
2011 CTS-V Wagon
post #3 of 4 (permalink) Old 03-27-2004, 02:53 PM
96bird's Avatar
Yeah I didn't even try. I figured that it wasn't even worth it.
Russell
96bird is offline
post #4 of 4 (permalink) Old 03-27-2004, 11:30 PM Thread Starter
4 Cam Bird's Avatar
I was having fun with the press and I had them so I figured I'd put them in. Good thing I popped one out and then checked the fit. Probably wouldn't have gotten so lucky twice.
2011 CTS-V Wagon
