cost to replace rear control arm bushings - TCCoA Forums
post #1 of 5 (permalink) Old 03-28-2004, 02:05 PM Thread Starter
Question cost to replace rear control arm bushings
So I did a search but did not find a speific answer. Has anyone had this done? I can not do it myself because of time and other constraints. I think my upper rear control arm bushings are shot. How much will it cost to have them replaced?
wm_sorg is offline
post #2 of 5 (permalink) Old 03-28-2004, 09:43 PM
Are you sure that you can't do it yourself? It's a real easy job. I just bought a pair back in January for about $40 ea @ O'Reilly's. Then I had the alignment checked.
A garage is going to want at least a few hundred dollars for this. Fyi, the upper control arm bushing has a funny keyed bolt hole that is off center. And this hole is too close to the edge and mine was cracked in two places.
Perch
perch is offline
post #3 of 5 (permalink) Old 03-28-2004, 10:24 PM Thread Starter
They sell the rear control arms also? Do you have a part number? How long did it take you?
wm_sorg is offline
post #4 of 5 (permalink) Old 03-28-2004, 10:36 PM
Oops. I just rememered that I used a press to put the bushings in the upper control arm. You'd need to take 'em to a machine shop. I couldn't tell you how long it took. I replaced just about everything in the rear suspension. I still think it'd be cheaper to do it yourself.
Perch
perch is offline
post #5 of 5 (permalink) Old 03-29-2004, 01:17 PM Thread Starter
Thanks. How long did it take you to get them out?
wm_sorg is offline
