lowered bird, have questions - TCCoA Forums
post #1 of 2 (permalink) Old 03-30-2004, 10:48 PM Thread Starter
jk69cat's Avatar
my newly aquired 92 sport has eibach lowering springs on it, im in the process of looking over the car and seeing what all it needs and while doing this discovered that the rear sway bars links area problem, the right is just flat out gone, and the left looks like its going to break. the left one looks shorter than stock, and the stock ones were in a box in the back of my car when i got it, i would like to just reuse these, or get the right replacement. the question is, does this car have a addco sway bar? is there any identifiying numbers on them? and anything i should look at in particular? are they all 1.25? any help would be great.
mn12 less!
jk69cat is offline
post #2 of 2 (permalink) Old 03-31-2004, 06:50 AM
miller1995's Avatar
Addco makes bars in sizes 1.125, 1.25, and 1.375. If you have calipers its easy to measure the diameter of the bar, otherwise I would take a piece of string and get the circumfrance (sp?) and use a little geometry to figure the diameter.
Hope this helps, also check out the tech article for stock bar sizes.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
