1.25" drop?? noticeable change? - TCCoA Forums
post #1 of 25 (permalink) Old 04-03-2004, 01:16 PM Thread Starter
i was lookin on ebay n i found the tokico package w/ shocks and 1.25" springs for $325..i got stock 16"s w/ 225/60/16's...anyone know wat that would look like?
blackbird96 is offline
post #2 of 25 (permalink) Old 04-03-2004, 10:09 PM
dode's Avatar
Picture the way your car looks now, only 1.25" lower. Got it? Good, that's what it will look like!
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #3 of 25 (permalink) Old 04-06-2004, 03:03 PM
Hmmmm...are you sure it wouldn't look the same only 1 1/4" lower???
ChampagneTastes is offline
post #4 of 25 (permalink) Old 04-06-2004, 04:26 PM
I think it will be closer to 0.0001578283 Furlongs lower...
use the search thinnggyyy... It works.
SkunkWorks is offline
post #5 of 25 (permalink) Old 04-10-2004, 10:01 AM
Ohhhhhhhhh...you mean like .00000635 leagues lower!
Now I get it.
post #6 of 25 (permalink) Old 04-10-2004, 10:48 AM
Send a message via AIM to chrisnack
16" sport wheels
225/60/16 Potenza RE750s
Eibach kit (about 1.75" drop)
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #7 of 25 (permalink) Old 04-10-2004, 10:58 AM
Mmmmm...nice stance!
post #8 of 25 (permalink) Old 04-11-2004, 08:25 PM
I am sure the drop would be noticable to most who know how to look at a car. My question is, can you notice a difference in the handling? Looks is good but corning is even better.
Bluethunder
Bluethunder is offline
post #9 of 25 (permalink) Old 04-12-2004, 08:21 AM
Bluethunder
Yes BIG difference.
NSN Motorsports
'96 Eagle Talon ESI
post #10 of 25 (permalink) Old 04-12-2004, 03:20 PM
I second Chris's response. I noticed a BIG difference. Anytime you lower that much weight's center of gravity, combined with higher springs rates and increased dampening control (good shocks), the outcome's GOTTA be good!
post #11 of 25 (permalink) Old 04-12-2004, 05:12 PM
Send a message via AIM to slayer
Just wanted to say [email protected] asses
Sam
slayer is offline
post #12 of 25 (permalink) Old 04-13-2004, 11:00 AM
Sam
for what?
NSN Motorsports
'96 Eagle Talon ESI
post #13 of 25 (permalink) Old 04-13-2004, 03:32 PM
Sam
Hey, feel free to drop by and say smarta$$es anytime!
post #14 of 25 (permalink) Old 04-14-2004, 02:22 PM
JoeyICU's Avatar
the tokico springs seem like they would be wound extreamly tight and have a very tight ride....looking on mn12 perf the tokico springs start out at about the sport spring resistance...but then get extreamly tight extreamly quick....anyone have these and have comments on ride quality of them?
JoeyICU is offline
post #15 of 25 (permalink) Old 04-14-2004, 05:08 PM
I have a set of Tokiko shocks and struts and they ride nice. I am also dropped about 1.5 with a set of Eibach sport springs.
MN12-Blackbird is offline
post #16 of 25 (permalink) Old 04-14-2004, 05:28 PM
96bird's Avatar
Tokico-Sport Lowering Springs are of the linear design and offer cold wound steel that is powder coated for a lifetime of protection. Tokico offers one kit for the 89-97 Thunderbird and it is designed to lower the car 1.25". The front spring rate is 326 lbs per inch and the rear spring rate is 577 lbs per inch with a freelength of 15.70" in front and 11.07" in the rear.
They are the same rate at any height.
96bird is offline
post #17 of 25 (permalink) Old 04-14-2004, 07:35 PM
JoeyICU's Avatar
i thought with the linear desighn the spring rates double each inch...like mn12 says...and like i thought?
JoeyICU is offline
post #18 of 25 (permalink) Old 04-14-2004, 08:01 PM
96bird's Avatar
Yeah 326lbs/in. for 1 inch, 652lbs/in. for the 2nd inch, etc. But what you said was...
The LX Sport Option:
Front: 349-403 lb./in.
Rear: 509-637 lb./in.
That would mean that the tokico springs are lighter (in rate) than the sport springs for the first inch and much lighter for each successive inch. The sport springs are a heavier spring for the rear also. You make it sound like the tokico are a stiff spring when they are really online with regular V8 springs in rate. When lowering a car most people would want a bit of increased spring rate to deal with the fact that you have less travel available.
Russell
96bird is offline
post #19 of 25 (permalink) Old 04-14-2004, 08:05 PM
96bird's Avatar
Your ride quality is going to be determined by a number of factors and the biggest is the type of shocks that are on your car. Lowering springs and Bilsteins gave me a better ride than it had stock.
96bird is offline
post #20 of 25 (permalink) Old 04-14-2004, 09:59 PM
JoeyICU's Avatar
i feel dumb...so its like cut lx springs almost...tokico shocks are very good but bilsteins do have a better ride quality...im not sure if there actually stiffer...but...there at the least equivilent....i guess the best and only mn12 lower spring to look for are becoming eibach
JoeyICU is offline
post #21 of 25 (permalink) Old 04-14-2004, 10:35 PM
96bird's Avatar
I didn't say that it was like cut LX springs. Tokico springs are fine. The springs don't matter as much as you would think but that is a more involved discussion. I have Susupension techniques springs and they do just fine...
Russell
96bird is offline
post #22 of 25 (permalink) Old 04-14-2004, 10:42 PM
The Great Obucina's Avatar
Bilsteins are stiffer than OE shocks out of the box. They are considered heavy duty by Bilstein. Dont forget about H&Rs and Suspension Technques also. They are both linear springs. My ride quality is just fine with Konis and Eibachs.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #23 of 25 (permalink) Old 04-15-2004, 07:48 AM
JoeyICU's Avatar
yeah...someone said the ST's have quality issues but i doubt it....eibachs seem to be the best except i dont like how low the car is...MT's springs seems very good but im glad i didnt get into that deal...i just want better performance at or a little bit higher then eibach ride hieght
JoeyICU is offline
post #24 of 25 (permalink) Old 04-15-2004, 12:48 PM
When you say "ST" springs, don't confuse "Suspension Techniques" with the "Spring Tech" springs that are sold on Ebay. Suspension Techniques have been around for years, and have always been a leader in suspension mods for all cars. I've never heard of them having quality issues.
post #25 of 25 (permalink) Old 04-15-2004, 12:50 PM
Eibach and call it a day. on a good set of 245/40 nittos tooka nice circular off ramp @ 55+ thanks to tthem and the wide rubber.
