Spring question - TCCoA Forums
post #1 of 5 (permalink) Old 04-12-2004, 05:54 AM Thread Starter
Unhappy Spring question
I have a 93 cougar, and I have some bad saggage of the rear end of the Cougar. This usually happens when I have any extra amount of weight in the trunk. Will just some new shocks fix this or will I have to buy springs/ progressive springs? Please advise.....
SilverKat is offline
post #2 of 5 (permalink) Old 04-12-2004, 09:04 AM
dode's Avatar
Shocks will do nothing for you. You are basically overloading your springs. Progressive springs will not help you a lot either. A linear spring will actually be more beneficial in this case.
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #3 of 5 (permalink) Old 04-12-2004, 09:06 AM
JustinH's Avatar
if the springs are blown out then either put new ones in, or get a airlift airbag kit to put inside the spring to help it out.
The airlift hit is like 60 bucks at summit I beleive.
JH
JustinH is offline
post #4 of 5 (permalink) Old 04-12-2004, 07:13 PM Thread Starter
Which ones should I buy, the adjustable or regular? Also are they difficult to install?
post #5 of 5 (permalink) Old 04-12-2004, 07:15 PM Thread Starter
Uhh NM the one that says for Cougar.....derrrr
