Poly bushings, anyone ever tried this? - TCCoA Forums
post #1 of 2 (permalink) Old 04-17-2004, 09:10 AM Thread Starter
4 Cam Bird's Avatar
I am thinking about drilling a hole (or two into the wider ones) and putting a grease zert on there. Think it would help? Or is that a horrible idea. I am referring to the bushings for the mounting points of the control arms mostly.
2011 CTS-V Wagon
4 Cam Bird is offline
post #2 of 2 (permalink) Old 04-18-2004, 03:12 AM Thread Starter
4 Cam Bird's Avatar
Eh, nevermind, the bushings weren't causing the problem. The sway bar appeared to have clearence, but then the car settled down and it ended up hitting the metal that drops down from the frame rails right above the bar. Sawzall to the rescue.
2011 CTS-V Wagon
