Upper A Arm Install Thanks... - TCCoA Forums
post #1 of 5 (permalink) Old 04-20-2004, 10:00 AM Thread Starter
Thumbs up Upper A Arm Install Thanks...
Last week I replaced the upper A-arms on my 94 because they were shot and ready to fall off.
Now mind you, I've had this to 6 different shops/dealerships to find a popping in the front suspension while turning.... and I quote, “We can’t find anything wrong, the suspension is tight”…. Well then they must have been friggin’ BLIND!!! Have I mentioned lately that I hate shops/dealerships...
The left ball joint had approx 1/4" of vertical play (yes, 1/4") and the right had about 1/8" vertical play.
Anyway, the install went without a hitch and all the nuts and bolts came out without any problems. So now I have new upper’s with poly bushings, new front shocks, freshly turned (non-warped) rotors, and new caliper pins and boots.
I just wanted to say thanks to whomever posted about getting the ratcheting wrench. I can't imagine doing that job without that tool!!
So thanks!
69 F100 LWB w/460 Engine
post #2 of 5 (permalink) Old 04-20-2004, 11:23 AM
rustyul's Avatar
I've done it without a ratcheting wrench. It was in the dark with a trouble light, and I kept thinking to myself..."This is what a ratcheting wrench was designed for....I wish I had one!"
Oh well, I've got to do it on my Cougar soon, so I'll get the wrench this time!
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #3 of 5 (permalink) Old 04-20-2004, 01:04 PM Thread Starter
I bought two specifically for this job:
18 mm standard boxed/open end to break the nuts loose (I had one, but it was short, so I bought a newer longer one)
18 mm ratcheting boxed/open end to remove the nut.
Worked like a champ!
I'll eventually buy a complete set.
post #4 of 5 (permalink) Old 04-20-2004, 05:18 PM
You're Welcome!!!!!!!! Glad someone took my advice finally, makes it a much easier job.
Rich95XR7 is offline
post #5 of 5 (permalink) Old 04-20-2004, 06:24 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
I did it without the racheting wrench because the racheting wrench set I had was SAE not metric It probably would have been a lot easier had I actually been able to use them.
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
