front sway bar bushings - TCCoA Forums
post #1 of 2 (permalink) Old 04-21-2004, 10:54 AM Thread Starter
girdnerg's Avatar
Question front sway bar bushings
Doing the 02 exployer swap and thought I would change the sway bar bushings while the motor is out.
Can anyone give me a link on where to buy just the front sway bar bushings (in poly preferably) at a reasonable price?
Also, can you tell me what size the front bar is on a 95 xr7 with 4.6l?
thanks
rob
girdnerg is offline
post #2 of 2 (permalink) Old 04-21-2004, 03:31 PM
4 Cam Bird's Avatar
They come with the front suspension kit that MN-12 performance sells. I put bigger sway bars in so I didn't use them. I think I still have them though. E-mail me at [email protected] and we can figure out a price and arrange shipping. I'll sell 'em cheap.
2011 CTS-V Wagon
4 Cam Bird is offline
