Moog Rear Inner Upper and Lower P/N - TCCoA Forums
post #1 of 6 (permalink) Old 04-22-2004, 02:48 PM Thread Starter
Question Moog Rear Inner Upper and Lower P/N
Does anyone have the part numbers for new bushings for the upper and lower arms on the rear?
I already have poly's for the knuckle, and I'd like poly's for the inners, but I don't think they are available. So I'll be forced to go back with OEM.
69 F100 LWB w/460 Engine
post #2 of 6 (permalink) Old 04-22-2004, 04:52 PM
fast Ed's Avatar
Here's what I see in the MOOG catalogue in front of me ...
Upper arm, to frame K8562
Upper arm, to knuckle K8588
2 kits required per car
Lower arm, bushing kit K8568
Lower arm, cam bolt kit K8522
cheers,
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 6 (permalink) Old 04-22-2004, 11:24 PM
The Great Obucina's Avatar
the arm bushings might not be poly. I got a set of Moog front UCA bushings and they were rubber Then again, I am not right from time to time.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 6 (permalink) Old 04-23-2004, 06:29 AM Thread Starter
Yeah, the Moog parts are OEM (or slightly better maybe) or so I've been told.
The Poly's aren't available anywhere to my knowledge, but I want at least new, not 266K miles like I have on mine now.
fast Ed N: Thanks very much for the part numbers!!
post #5 of 6 (permalink) Old 04-26-2004, 07:32 AM Thread Starter
Can someone double-check these numbers?
On Rockauto, I'm coming up with a slightly different number for the lower arm to frame bushing:
K8658 vs. K8568
Unfortunately, they are both legitimate part numbers.
I think the correct number is: K8658 (Moog or Spicer; Rr Susp; Lower; To Frame; 2 required; Control Arm Bushing)
The order is going in soon and I don’t want to get the wrong part.
Thanks.
post #6 of 6 (permalink) Old 04-26-2004, 03:23 PM
Your eyes are playing tricks on you.
I couldn't find K8568. I think you mean K8562.
Upper rear arm to frame: K8562
Lower rear arm to frame: K8658
Sources: RockAuto and the Moog part look-up the Federal-Mogul web site
Astaeroth is offline
