Moog upper ball joint part #s - TCCoA Forums
post #1 of 10 (permalink) Old 04-25-2004, 11:01 PM Thread Starter
Tinfoil hat wearer
azreael344's Avatar
Send a message via AIM to azreael344 Send a message via Yahoo to azreael344
Does anybody here have the part #'s for the moog upper ball joints the ones that have the grease fittings?
1996 Laser red 4.6 V8.
Flowmaster catback, PI Intake, PI cams K&N 9 inch cone filter 80mm LMAF, Trickflow plenum, 75mm BBk throttle body,SCT Chip, Red FRPP wires, 22c plugs & 180* t-stat, PBR calipers, ASP underdrives. Marauder torque converter, FRPP 3.73 gears, Custom Drive shaft, Eibach Springs, Tokico shocks, JMOD, B&M 24k Tranny Cooler, Clear corners, 145mph Speedo,17X9 Cobra R's, Complete SC interior including SC Handbrake conversion
Best time [email protected] 93.18 MPH 4/16/2004
My other ride: 2001 F150 4x4
Aol screen name: Azreael344
azreael344 is offline
post #2 of 10 (permalink) Old 04-26-2004, 09:54 AM
afaik yopu can't get the uppers seperate from the control arms. Someone else may know different??
doodaa is offline
post #3 of 10 (permalink) Old 04-26-2004, 03:42 PM
I far as I can find, Moog doesn't sell just the upper ball joints for our car. I believe if get in the Zone, AutoZone (or similar store. I was just being sarcastic about AZ)... you can buy upper ball joints separately. But by the time you waste time and money buying them, then pressing the old ones out, pressing the new ones in, you'll have bent the arm. It's just easier and not that expensive to buy the whole arm w/ ball joint.
Front Upper Left Control Arm w/ Ball Joint: K8596
Front Upper Right Control Arm w/ Ball Joint: K8598
And if they don't come with the grease fitting, usually you can take the cap off and put a fitting in. I haven't gotten to replacing my own upper arms yet, so I can't remember off the top of my head if they come with fitting. But they probably do.
Astaeroth is offline
post #4 of 10 (permalink) Old 04-26-2004, 06:06 PM Thread Starter
Tinfoil hat wearer
azreael344's Avatar
Are those Moog part #s
post #5 of 10 (permalink) Old 04-26-2004, 06:29 PM
The Great Obucina's Avatar
yes....I had the same ones. Remember, its the entire arm, not just the ball joint, the upper balljoint in not seperately serviceable.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #6 of 10 (permalink) Old 04-26-2004, 06:42 PM
Moog and TRW are the same for these parts, one make them for the other. As for the part# for the greaseable type, its a hit/miss game. Same part # for either kind, so open the box and see if you have the greaseable one or sealed type.
SCme is offline
post #7 of 10 (permalink) Old 04-26-2004, 07:08 PM Thread Starter
Tinfoil hat wearer
azreael344's Avatar
around how much do they cost?
post #8 of 10 (permalink) Old 04-26-2004, 08:22 PM
Cougar Pilot
BlackCat94's Avatar
Joseph there knows where to find a good price on thoes UCA's I believe. Tell us where that is. Thanks.
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #9 of 10 (permalink) Old 04-26-2004, 10:06 PM
Well,
I get almost all of my parts from locally based parts stores. I usually just call around to find the best price and try to play one store against the other. I usually get a few dollars knocked off the price. RockAuto is all fine and dandy but I can get a part like control arms in a day from one of the local chains here in Florida. I think I paid 55$ or so for my upper arms. They were Moogs....
I get almost all of my parts from either Congress Auto or Bennett Auto Supply. Problem is, they are only found in Florida.
joseph
post #10 of 10 (permalink) Old 04-27-2004, 12:20 AM
Cougar Pilot
BlackCat94's Avatar
That's right on par with Rock Auto's prices. I thought you knew a better place, sorry.
